Old 10-07-2014, 12:58 AM
mikethebike1127 mikethebike1127 is offline
Default Starter motor
Hi there
Been reading that a DRZ400 starter motor fits straight onto a 2004 450FSE. Can anyone confirm that for me.
Cheers in advance
Mike
Racist????.....Not me
I'll race any one !!!!
Old 09-19-2015, 12:14 AM
Default I does fit however!!!
I can confirm that the Suzuki starter motor does fit however, the positive terminal is on the side of the starter (instead of the end) which fouls the chassis. This is an easy fix....either drill the end cap to suit or use the Gas Gas end cap and rubber grommet. Another issue is the Suzuki unit spins the wrong way!!!. Easy fix....use the Gas Gas brush mounting plate...the brush configuration on it spins the starter the "correct" way.
Old 12-09-2017, 06:48 PM
Lambretta man Lambretta man is offline
Can you please supply pics and maybe a part number for the gas gas brush mounting plate please thanks
250 motor fullthrottle General Discussions & Announcements 9 11-27-2013 05:23 AM
will 05 starter motor fit 03 fse450 hillbilly Enduro Engine 4 stroke (including EFI & Exhaust) 0 07-01-2010 01:06 AM
04 starter motor pondmore Enduro Engine 4 stroke (including EFI & Exhaust) 2 06-23-2007 04:56 AM
