Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 10-29-2008, 06:59 AM
GMP's Avatar
GMP GMP is offline
It appears to be a two piece unit, which is nice if you can get the pedal arm as a replacement part for less $ than the complete assembly. I wonder if the pivot section is steel.
I also make a simple mod that eliminates the wear issue with the hole for the master cyl pin. I fill the hole, redrill and tap for M6. An M6 bolt and two steel weldnuts mounted flange out capture and provide a steel surface to slide within the clevis, eliminating the steel on aluminum wear. On the older bikes with the frame mounted pedal height adjustment this is especially nice because you can cut the bottom out of the clevis (forming a slot) and now you have a one bolt eaiser to R&R brake pedal.
I've thought about the brake pedal issue for awhile, and if your going to use a heim (spherical) joint for the master cyl connection, you need to modify the Nissin master cyl piston pin for more freeplay like the Brembo on the KTM, as the clevis slot provides this.
Next week I'll have a lot more free time and catch up on my photo gallery so you can see this.
Old 10-29-2008, 04:02 PM
mxdj2003 mxdj2003 is offline
im actually working on a new pedal with the bearings in it , i should have one built this weekend it will be a two piece unit like the one pictured in this post, it wont have an alumnim tip i was planning on using a KTM pedal tip as they are cheap and it is easier to buy then machine one .
Old 11-21-2008, 07:13 AM
spondon9 spondon9 is offline
Default KX brake pedal
Hi Peeps,
any one know much about the KX brake pedal to fit a EC 250 07?
Old 12-16-2008, 05:28 PM
Berkyboy's Avatar
Berkyboy Berkyboy is offline
The mecasystem brake pedal is now in stock and ready to ship.
$89.95 at current Euro values.
Dealer pricing available.
We also have the mecasystem skid plate in stock for 05 and newer (200/250/300) 2-strokes...$129.95.
Steve Berkner
I've attended 21 Six Days as a working Photojournalist
Old 12-16-2008, 07:42 PM
Rick's Avatar
Rick Rick is offline
Will the Meca System pedal fit my 99 EC200?
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 12-16-2008, 09:29 PM
Berkyboy's Avatar
Yes, the packaging says it will fit!!
Steve Berkner
Thread Tools
Display Modes
Rear brake pedal HydroDog Enduro Chassis & Body 0 03-09-2008 10:48 PM
2002 rear brake pedal kevin849 Enduro Chassis & Body 5 03-07-2008 12:08 PM
Rear Brake Pedal Rick Enduro Chassis & Body 4 01-28-2008 01:57 PM
