Old 04-28-2020, 07:18 AM
stinger32 stinger32 is offline
Default Sachs 48mm ?hlins fggg 1082 oil volume
I'm a bit confused regarding oil volume. Std sachs 48 mm require about 600cc of oil in each leg and when using fggg1082 I shall only use 280cc in each leg regarding to this link https://www.ohlins.com/app/uploads/w...I_FGGG1082.pdf correct?
Old 04-28-2020, 07:01 PM
I suspect that is because you are going from open cartridge to closed cartridge forks. I think that would be the volume in the outer tubes. the cartridges would be full of oil
Just speculating, the info seems a bit vague where are the rest of the steps?
Sachs/Reiger/?hlins MargusV Enduro Suspension 6 10-22-2016 10:08 AM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
WP 48mm oil volume??? Dealer sounds crazy! nambo-trev Enduro Suspension 4 10-04-2012 01:06 PM
Sachs 48mm Bushings Jakobi Enduro Suspension 9 06-19-2012 07:18 PM
Sachs vs. ?hlins Madhead Enduro Suspension 7 01-22-2012 07:22 AM
