seized piston EC 300 2018
Hi guys did the first top end on the gasgas after 100h the piston and cilinder was like this:
I didnt notice this happening, the bike had so much torque whit this, could not even imagine this. Is it ok to put a new piston on this cylinder? thx. |
Can you feel the marks with your fingernail? Hard to tell with pictures but, it looks like it may clean up.
Sent from my iPhone using Tapatalk |
On The piston The i can feeling The marks on The cylinder i almost cant feel it.
Sometimes, the marks on the cylinder are just the anti friction coating from the piston. You may be able to carefully polish this off the cylinder with a scotchbrite pad.
The Nickasil cylinder plating is rock hard so you won't damage it with a scotchbrite but don't be tempted to use a cylinder hone. |
On The piston i can feel The marks on The cylinder i almost cant feel it.
I would try to clean it up with scotch brite. In the photos you can still see the cross hatching under the scaring. I wouldn’t be afraid to put a piston in it and run it after cleaning the cylinder up a bit. Remember though, this is only an opinion based on pictures.
Don't forget to check and adjust/file new rings to give the correct ring end gap. All the best, Dave. |
There are bristle brush type hones made for nikasil that will most definitely clean up marks like that and are safe to use. My old 04 gassy had over 20,000km on the plating and was still within spec. The key in my opinion is to not try and get 100 hours out of pistons. I do mine at 50-60 hours max and have never had any seizures. See if this link works. http://www.enginehones.com/niapho.html
Also run a good quality premix oil at an appropriate ratio. How is the bike jetted? Did you ever run out of fuel while under a high power condition?
I use the ball hone just to knock the glaze off the cylinder. You can't go hog wild with it. Just a couple easy passes. |
Thread Tools | |
Display Modes | |
2018 ec250 piston and gaskets | Wuzofoz | Enduro Engine - 2 stroke | 4 | 10-29-2018 05:45 AM |
2018 KYB AOS Fork Free Piston | Jacob 'Berg | Enduro Suspension | 5 | 09-17-2018 04:47 AM |
Seized front axle | sheepy | Enduro Chassis & Body | 7 | 06-08-2018 03:55 AM |
Hot seized engine??? Help please | Lenard999 | Enduro Engine - 2 stroke | 9 | 04-14-2017 11:15 PM |
Seized 250? | eff | Enduro Engine - 2 stroke | 22 | 11-13-2009 07:33 AM |
