Old 02-23-2019, 10:29 AM
Mikesbaron Mikesbaron is offline
Default Which airfilter cage? ('07 FSR450)
I just picked up and FSR450, it didn't have the air filter cage. I'm wondering if there are other model cages that will fit?
I'm also concerned about how this OEM set up does not have any way to securely keep the filter in place without it shifting or rotating around the mounting surface opening. Is there a retrofit or other model filter setup that is more secure?
Or am I just going to have to order an oem filter cage in deal with it?
Old 02-23-2019, 06:54 PM
frankinberg's Avatar
07-11 use the same cage there is a spring device that holds it in as far as I now is stock is the only option
Old 02-26-2019, 08:58 AM
I've been to every OEM Gas Gas order site I can find and can't find anything from Gas Gas here in America.
There has to be another item from a Jap bike that can match up.
Old 03-09-2019, 09:46 PM
I I found the 07 to 2011 two-stroke cage fits but you have to use the two stroke air filter element.
Air filter cage Puunui Enduro Intake/Carburetion - 2 stroke 6 03-16-2018 10:56 AM
2007 airfilter the same as 2013? rubber Jonny Enduro Intake/Carburetion - 2 stroke 5 04-22-2016 01:19 PM
Air filter cage support Cox76y Enduro Intake/Carburetion - 2 stroke 0 07-16-2015 06:00 AM
About that Twin-Air Billet Cage... AZRickD Enduro Intake/Carburetion - 2 stroke 5 03-27-2015 09:27 AM
Seat cutting into Airfilter Jakobi Enduro Chassis & Body 10 05-10-2011 08:41 AM
