Old 04-13-2007, 09:43 PM
gasIdaho gasIdaho is offline
Default Stalling on the downhills
For the most part my bike runs great and is jetted to my satisfaction. The idle surges a little bit depending on whether in neutral or in gear. Problem I'm having is stalling when going downhill, clutch handle pulled all the way in...basically coasting. Happens more on very steep descents. I read an earlier post that mentioned a float height adj. Any suggestions on which direction to go and how much adj. to make?
05' EC300
Old 04-14-2007, 07:52 AM
eff's Avatar
eff eff is offline
I'll be interested in this too. On my last ride my bike ran great, except at closed throttle. When I did the bike surged like you refer to.
I have not done anything to fix it yet, but I am going to check the fit of my airboot and float height first.
Old 04-16-2007, 12:16 AM
kim kim is offline
Make sure you are only using 900mls of oil in the gearbox and not 1 liter as the manual says. The clutch behave much better with slightly less oil.
Also make sure you are using the correct oil, check previous thread for some options.
Kim
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Stalling down hills? nick790 Enduro Intake/Carburetion - 2 stroke 3 09-05-2009 02:28 AM
Another 450 with stalling problems mrsticky Enduro Engine 4 stroke (including EFI & Exhaust) 3 06-11-2009 11:37 AM
Bike stalling out smnl4l Enduro Engine 4 stroke (including EFI & Exhaust) 6 11-19-2008 11:06 PM
Question: Stalling? Tinks United Kingdom 2 02-25-2008 08:11 AM
'02 ec300 stalling in water ec300 2t Enduro Electrical & Wiring 1 01-15-2007 09:05 PM
