Old 03-16-2012, 09:27 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
Originally Posted by GMP View Post
I checked, Styrene Butadiene (SBR) or Ethylene-Propylene (EPDM) are what you want for brake fluid, and are poor choices for petroleum base oils. You should be able to get these from a good o-ring supplier. The parts list just shows a kit, no separate o-rings
Brembo, I missed that, that explains it.
Yeah I just found an o-ring guide that listed the EPDM type for brake fluids. I saw the ring is in the kit, too. I looked at a 2003 model parts cat. I don't want to pay $40 for an o-ring! I'll have to measure it up and try to source one.
This Brembo bore is stamped 10. I'm not sure what the AJP is. You know?
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 03-16-2012, 10:07 PM
If its like the Magura it's the bore dia. Their way of designating displacement. This was being discussed in another thread. The AJP is not marked, but seems to be a bit less displacement. You should get slightly more travel, so less drag, but a slightly harder pull. When you put it together and bleed it just make sure the slave doesn't overtravel. Gasgasman swapped in a 10.5 Magura so you should be fine.
Old 06-26-2014, 08:00 PM
bluespark's Avatar
bluespark bluespark is offline
I went to Autozone to look for some hydraulic jack oil and found this.
Would this be a suitable substitute for clutch mineral oil?
Old 06-26-2014, 08:19 PM
djroggen's Avatar
djroggen djroggen is offline
Default Clutch Hydraulic Fluid ?
If your gonna substitute just use baby oil. Works like a charm, smell only lasts a few hours.
Not to mention it is very cheap.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 06-27-2014, 08:10 PM
bluespark's Avatar
I thought I had read somewhere that the johnsons baby oil was too thick?
Old 06-28-2014, 12:23 PM
djroggen's Avatar
I have used it for 4 yrs now, no issues. If you looks it's like 99.7% mineral oil. My percentage is wrong pry but close.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Old 06-30-2014, 08:41 AM
Rod Overstreet Rod Overstreet is offline
Been using ATF since 2000....Dextron 2. Not sure what the boiling point is of baby oil, but I've yet to burn up ATF.
I've also seen 5wt fork oil used.
Old 07-01-2014, 11:38 AM
bluespark's Avatar
Ok thanks guys.
Hydraulic Clutch on EC 250 not engaging jprh Enduro Engine - 2 stroke 2 03-01-2009 05:54 AM
Hydraulic Clutch Oil?? jyellard Enduro Chassis & Body 10 10-01-2008 01:34 AM
Hydraulic Fluid for the clutch lukachuki Enduro Engine - 2 stroke 2 09-22-2007 05:59 PM
Im looking for a Grimeca Hydraulic Clutch brian27 General Discussions & Announcements 3 06-21-2007 02:33 PM
