Old 09-24-2009, 10:28 AM
SpeedyManiac's Avatar
Default Top End Clearances/Specs
Need some quick answers, can't find them anywhere. What are the tolerances for piston/bore clearance? I've heard 0.06mm, but need max/min numbers.
Thanks,
Steve
Old 09-24-2009, 10:35 AM
widebear's Avatar
widebear widebear is offline
Banned
one and a half thou of a inch min, max is up to you but I dont like to run more than .003 inch, two stroke sleds are known to run seven thou on fresh cast pistons.
Old 09-24-2009, 05:02 PM
gasser's Avatar
gasser gasser is offline
Good info on this link (go to the long post) :
http://www.thumpertalk.com/forum/arc.../t-430827.html
I have the official GasGas numbers somewhere I'll see if I can find them. - Ken
Old 09-24-2009, 05:40 PM
gasser's Avatar
This is from the GasGas 2006 shop manual:
Clearance between piston and cylinder:
200 std:0.05mm , limit: 0.10mm
250 std:0.055mm , limit: 0.10mm
300 std:0.06mm , limit: 0.10mm
Ring Gap:
200 std:0.3mm , limit: 0.6mm
250 std:0.4mm , limit: 0.7mm
300 std:0.5mm , limit: 0.8mm
Cylinder Bore:
200 std:62.50mm , limit: 62.60mm
250 std:66.38mm , limit: 66.50mm
300 std:71.99mm , limit: 72.10mm
Old 09-24-2009, 09:53 PM
Also depends somewhat on what piston were talking about. I'm assuming the now OEM Vertex.
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
rake and trail specs widebear Enduro Chassis & Body 9 01-28-2009 05:52 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
400 fse cam/valve clearances captainslow Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-26-2008 05:19 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
