Old 06-14-2019, 01:26 AM
Kaarel Kaarel is offline
Default 2013 300EC bendix
Hello,
Electric starter on my bike stopped working. I removed the cover and discovered that bendix doesn't "fly" out like it supposed to do. Cleaned and lubed it, but nothing.
I discovered that the shaft rotates in the large gear wheel. Doesn't it have to be there tightly?
Best regards
Kaarel
Old 06-14-2019, 05:00 AM
Gasser Nate's Avatar
Yep it is supposed to be a press fit. You need a new bendix. I have tried in the past to tig weld them with some success.
Old 06-14-2019, 09:58 AM
Nocams Nocams is offline
Yep, I?ve had success with the mig when mine spun itself in two years ago.
2011 TXT300R
2018 EC300GP
Old 06-14-2019, 12:37 PM
RudolfHucker's Avatar
RudolfHucker RudolfHucker is offline
Had exactly the same happen on a 300 KTM 2T. Had to be replaced.
Old 06-15-2019, 02:42 PM
Biff's Avatar
Biff Biff is offline
Hi
There is a bendix that fits
Top of my head its smu5004 but I'll check Monday
Had problems on my 13
But cured them with mods on this site
Now my battery appears to lack power to spin up bendix to start.
Hooked up jump start to battery and all good.
Note - have dedicated neg wire from battery to starter motor.
Time for new battery ?
If so , lead acid or lithium?
Old 06-16-2019, 05:54 AM
fred99999au fred99999au is offline
Beware of the 220CCA SSB Lithiums with the LED Display on the top.
Old 06-17-2019, 01:21 AM
I welded it with TIG and it seems to work nicely. Thanks!
Old 07-03-2019, 07:22 AM
Unfortunately the welding lasted for 2 rides and now the shaft rotates again. The most problematic is that the manufacturer's warehouse is out of stock. Does this SMU5004 fit 1:1?
need:Starter Clutch Bendix 2013 EC300 64Opaka Parts 5 06-27-2016 01:19 PM
2013 300ec kickstart sticking? bones150 General Discussions & Announcements 1 08-14-2015 12:20 PM
Bendix weaver Enduro Electrical & Wiring 2 12-28-2014 10:50 AM
Brand New 2013 300ec? lornop General Discussions & Announcements 6 12-13-2014 09:18 AM
2013 Gas Gas 300EC $6900 gasgasrandy967 New Bikes 0 02-06-2014 01:51 PM
