Old 05-10-2019, 07:18 AM
GasGas's Avatar
GasGas GasGas is offline
Yes it could be the starter motor. Have your dealer look at it.
2018 EC 300
Old 05-10-2019, 06:08 PM
fred99999au fred99999au is offline
Pull the starter motor out (2 bolts and its sealed with an O ring) and put your finger in the hole and see how much resistance you feel turning the gear.
Should be next to nothing. Mine had crunchy bearings and the axle shaft was binding. '18 GP300
Old 05-10-2019, 06:29 PM
Gasser Nate's Avatar
That sounds like a bad starter motor to me. Sounds like it has a dead spot in the armature or a sticking brush. Have you pulled it apart to have a look? Or just out to make sure the gear the starter engages with spins freely?
Old 05-13-2019, 10:58 AM
eralha eralha is offline
Will check if it have resistance, i got the felling that something is binding and blocking the movement.
Old 03-23-2020, 05:37 PM
hannesd hannesd is offline
do all bendix covers fit a 2015 ec200?
looked on the site of AS3 and they only list one for 250 and 300 2017-2019?
cheers.
Old 03-23-2020, 07:55 PM
gg3's Avatar
gg3 gg3 is offline
Hi Eralha,
I had a win fixing the starter system.
Removed bendix & lightened the spring,polished the inside,cleaned & lubed the gears,made sure they were not binding- a little better but inconsistent.
Got a AS3 bendix cover (really nice gear)- when hot worked better.
Pulled the starter apart & checked it was clean & moving freely.
Put in a Shorei 210cca battery & it started easy.Starts hot every time now but I do kick start when cold.
Old 03-23-2020, 11:34 PM
TGM_OFFROAD TGM_OFFROAD is offline
Originally Posted by gg3 View Post
Hi Eralha,
I did all the same work and mine functions the same. Just make sure to pull the bendix evey 15 to 20 hours or so and clean and relube it up.
Old 03-24-2020, 06:46 AM
i got email from the guys at AS3 and the only bendix cover they do if for the 250/300 from 2017 to 2019?
2018 ec 250 clutch cover Leelee Enduro Engine - 2 stroke 3 02-13-2019 04:11 PM
Weak clutch disc cover, EC 2018 eralha Enduro Engine - 2 stroke 11 12-18-2018 03:46 PM
Rekluse Clutch Cover for 2018 MY Jacob 'Berg Enduro Engine - 2 stroke 10 05-30-2018 07:32 PM
bendix help Mostin3 Enduro Engine - 2 stroke 0 10-09-2017 05:48 AM
