#31
Whatever! Whats wrong with your dog. Hope its not serious |
#32
I raised the needle because it had a lean spot round 1/3 throttle and bogged with quick throttle input and still had some detonation. I put the nech needle on #4 and it felt 100% better than the stock needle but seemed to lean still due to detonation when trying to purposely lug up the little hills I have here. I am getting a hold of a new cdi box to plug in next week just to cross that off the list. |
#33
I listened to the videos again.
First two it blubbers down low as they all do. Thats caused by the NE1F which is very rich down low. It sounds much better through the rev range but I am not sure if that hesitation at WOT is caused by an overly rich mixture. I dont know the sound that good.... I don't want to be a pita and sorry if I annoy you but I think you change too many things at a time. From video 2 I had opened the air screw to 2 turns just to see if the blubber down low gets better. If it does not get much better, DROPPING the needle to clip 2 had been my next step. I am pretty sure that could have cured the blubber down low and the hesitation at WOT (if caused by richness). Cheers Doc PS: your idle seems to be too high. Set it as low as possible, accept that it may stall from time to time. I cant judge the third video.... |
#34
Could not hear detonation but I trust your words, no doubt. Its very strange that it detonates with the OEM set up. That really puzzles me as this set up is known to be rich. Maybe the problem is ignition related but if the woodruff key is ok and the flywheel hasn't moved on the crank....and the pick up isn't loose.... I have no idea. Has your CDI been updated. I can remember that we had to bring ours to the dealer who updated them. No clue what has changed... edit: missed that you used the NECH instead of the NE1F. Is the NECH richer than the NECW? Cant find my notes at the mo. |
#35
#36
I may be over sensitive due to recent events and think I am hearing detonation when I am not. But the times I heard it were off camera I think.
I dont know if the CDI was ever updated, I tried to find out when I got the bike but the closest dealer was 200 miles away and were not helpful. They also have dropped the Gas Gas line at this point. The guy I bought the bike from had a couple 19 CDI left over from the race team and he is going to give me one to see if it helps. |
#37
Took another crack at it today and it looks like the morning is going to be clear tomorrow so I am gonna go out for a quick trail ride. I put my jd jetting blue needle back in and it feels pretty good, a little rich still but will know for sure tomorrow when I can actually open her up and clear it out.
Here is how it sounds. Opinions? https://youtu.be/ec07rdf4-10 |
#38
When the bike is ridden with cold or not fully warmed engine the pipe stays cool and gets wet from fuel residue. As long as the pipe is wet and oily you'll hear it splutter a bit but that will go away once it is hot and has been revved. Yes, riding it hard in shorts on wet tarmac isn't a good idea. Hope your neighbours wont be too upset when you ride around their houses numerous times Good Luck! |
#39
Once you get the jetting correct you may want to give yourself a little detonation safety margin. You can retard the ignition timing by rotating the stator plate in the same direction that the engine spins. You will get about 1 degree of ignition timing for each 1mm of rotation measured on the circumference (outer diameter) of the stator plate.
That being said, I do not remember if the new bikes allow for ignition timing adjustment. |
#40
Thread Tools | |
Display Modes | |
Spark plug | eviljim | Enduro Engine - 2 stroke | 4 | 01-06-2013 02:35 PM |
spark plug help ec 125 | rmlt2008 | Enduro Electrical & Wiring | 5 | 09-16-2011 11:35 PM |
Spark plug? | Pepperami | Enduro Engine - 2 stroke | 3 | 06-28-2011 01:49 PM |
Spark plug | gasgas125sm08 | Enduro Engine - 2 stroke | 0 | 03-08-2010 09:42 AM |
Spark plug gap???? | Bandit9 | Enduro Engine - 2 stroke | 1 | 08-29-2007 05:26 PM |
