Old 12-17-2008, 09:04 PM
sanderjavant's Avatar
sanderjavant sanderjavant is offline
Default Fuel pump relay-where is it?
I have new fuel pump relay for a 2005 450 FSE but I can't find the old one on the bike to replace it.
Anybody know where it's located?
Could it be No 12?
Old 12-17-2008, 11:42 PM
coolum74 coolum74 is offline
Default relay
From what I have red here its behind the right hand rear side panel. Hope this works
Adam
2006 FSE450...Gone
2011 EC300e
Sunshine Coast, Queensland
Australia
Old 12-18-2008, 03:24 AM
bergerhag's Avatar
It is not shown in the parts book.
Old 12-18-2008, 06:50 AM
cladoo's Avatar
cladoo cladoo is offline
There are two relays there. I had to replace one once on a customers bike and the parts diagram does not show it. I replaced it with an automotive relay that was much stronger and it has worked fine since.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 12-18-2008, 09:51 AM
Nick's Avatar
Nick Nick is offline
The earlier post is right, its behind the right side number plate. There are two, one for the fuel pump and one for the fan.
Old 12-18-2008, 09:34 PM
I guess I didn't receive a fuel pump relay.
I had been having an intermittent problem with the fuel pump not firing when I turned on the key. Now it won't start at all.
I thought the fuel pump relay was bad and that it was located next to the battery under the right panel. I replaced the original with a NAPA relay but that didn't fix it. So I decided to order the factory part. When I received the part below I was hoping the the relay was still the problem but it was located somewhere else on the bike, not the relay next to the battery.
I want to ride my bike again. It's dirt bike season in Texas.
Old 12-19-2008, 09:36 AM
Nick's Avatar
Thats it minus the cover or shroud if you want to call it that, that surronds the spades on the relay. Will it fit with the shroud ? Also check your key switch. Unplug it and use a jumper, i've had it go fubar from water intrusion.
400FSE Fuel pump question Gi_GASGAS Enduro Engine 4 stroke (including EFI & Exhaust) 3 12-31-2019 03:58 PM
03 450 fuel pump voltages query hillbilly Enduro Engine 4 stroke (including EFI & Exhaust) 1 09-22-2010 04:21 PM
fuel relay Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 4 10-21-2009 04:12 PM
Fuel Pump Clips Broken KTMrider58 Enduro Engine 4 stroke (including EFI & Exhaust) 3 04-15-2007 04:18 PM
