#11
Button head allen bolt works good there. I tracked down a pipe rattle to the edge of the header flange vibrating on a spigot bolt head, when the o-rings were bad once. Those holes could use another mm of radius from the spigot center.
With all this said, you don't have to pull the spigot to change o-rings. Contact cleaner on a strip of rag works fine. |
#12
Lesson learned on removing the spigot... I didn't realize that there was loctite on the threads until I stipped the lower one.. The other two were fine.
I did notice that the pipe had three small gouges in it where it was wedged against the 8mm spigot bolts and vibrating. They could use some extra room in there. Button heads are a great idea but at this point, I am not touching it unless the spigot falls off. I do have to say that out of all the bikes I have owned, this one seems the most finicky regarding the "little things", like gas cap leakage, front fender brace, small bolts, odds and ends stuff that could be a bit sturdier. But I wouldn't trade the bike for anything!
'10 EC300 -- very happy |
#13
All thoroughbreds are a bit finicky !
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro Last edited by Fred1956; 09-23-2011 at 05:35 PM. Reason: spelling |
#14
Where do you get the viton o-rings? Tired of replacing the rubber ones twice a month!!
#15
I think they are 3mm x 44mm ID
Thanks to FLY Racing. |
Stripped bottom of Ohlins | prk03 | Enduro Suspension | 8 | 01-25-2009 09:03 PM |
Exhaust Spigot Bolts | eff | Enduro Engine - 2 stroke | 9 | 08-08-2008 06:38 AM |
Stripped screw in gas tank | prk03 | General Discussions & Announcements | 2 | 06-18-2008 11:19 AM |
stripped hex head | nhrider | General Discussions & Announcements | 11 | 05-28-2008 12:06 PM |
Stripped | Brian VT | Enduro Suspension | 4 | 12-09-2007 09:06 PM |
