Old 08-20-2012, 03:01 PM
rbm33 rbm33 is offline
Default 2013 question...
maybe it has been talked about already but i was wondering what the 2013 bikes will have for forks. it seems the Euro specs call for 45mm forks. this is the most complete list i have seen do far on the changes, stolen from thumper talk,....... i was under the impression that everyone was really happy with the 2012 fork setup so if they are changing back to the 45mm wonder what the reasoning is behind the change.
1. 6 degree increase in the turning angle.
2. Change in geometry of the rear suspension (New links) that provides greater grip, stability and better general performance. Also lower seat height.
3. Changed side of the steering lock
4. Suspension fine-tuned by HRG (Suspension specialists).
5. New filter access system (one bolt only).
6. Reinforced plastic cross-member
7. New top roller guide for the chain with built-in bearing (this will come in as a running change once we have used up the existing gusset plates, around 2000).
8. New brace for the front mudguard (the latest 2012 models were already fitted with them).
9. Reinforcement on side plates of the radiator. A bolt fixture is also to be incorporated.
10. Fixture of the side number panels with bolts to stop them from moving.
11. New, more modern valve cover.
12. New reinforced kick-start lever (the latest 2012 models were already fitted with them).
13. New bell housing, with oil release holes (for cooling) but more reliable.
14. New tank for better fit of the plastic
15. New attachment for the brake line guide so that it does not touch the fork mudguard.
16. New brake line with riveted cover to prevent the front wheel from pulling it in (the latest 2012 models were already fitted with them)
17. New side guards. (Frame guards).[/font]
Old 08-20-2012, 03:12 PM
twowheels's Avatar
US bound 2013 Gassers will feature the 48mm closed chamber Marzocchis.
Steven Beane #275
afterhourscycle.com
Old 08-20-2012, 05:11 PM
Diggs345's Avatar
Diggs345 Diggs345 is offline
And the uk race models , the 45 mm marz are to replace the 48mm sachs fork
Old 08-20-2012, 05:41 PM
v-tec v-tec is offline
Buying a new 300 here in the uk not the R
Are the 45 marz a bad fork, or do i buy a 2012 with sachs forks
Thats maybe how he steering angle has increased by 6 degrees, smaller forks,
Now im un-sure, the only thing i am sure of is what ever i get 12 or 13 the forks will have to be Tuned for my 70 kg body,
Old 08-20-2012, 11:35 PM
twowheels's Avatar
The best thing about the 45mm Marzocchis is that lots of tuners can help you make them work for you. The 48mm Zokes are better to the degree you can hardly believe they're from the same company. My opinion is that the Sachs have the potential to be a better fork, but fewer tuners will entertain the prospect of working on them.
As for the increased turning clearance, it has been suggested a slight modification to the upper spars is responsible for the gains. We shall see ...
Steven Beane #275
afterhourscycle.com
Old 08-21-2012, 04:01 AM
Die Tante T. Die Tante T. is offline
I was a big fan of Mazocchi forks till I rode the 48er Shiver CC in the 2011 Nambotin. I never had a fork which works so bad like the 48er Shiver. I rode the 45er Marzocchi in my Husky?s 2004 an 2005 model and they worked well. Also the KYB in the 2010er Husky was o.k. ! I was very suprised about the bad performance of the 48 Shiver and didn?t managed to find a setup for me. Now I changed to the ?hlins Fork..and I never had ride such a good fork out of the box...nothing to do for a better setup only a few clicks for different tracks.
"..they grow old because they quit playing"
Old 08-21-2012, 04:08 AM
Vindicator Vindicator is offline
Did the tank size decreased back to 9,5L ?
Vindicator
'11 EC 300R
Old 08-21-2012, 07:32 AM
3beejay3 3beejay3 is offline
Not sure how you had a bad experience with the 48 cc's (w/PFP adjustment), as everyone else raves about them............
Also the 45 Marzocchis used on the Huskies in the 04-07 years were generally regarded as a poor fork; bad valving, poor action etc., etc. They used mediocre technology from the early 90's & didn't apply it well at all.
Old 08-21-2012, 08:09 AM
Clay's Avatar
Clay Clay is offline
Banned
That's funny. My experience was totally opposite. I don't like the Ohlins because they blew through the stroke too easily (that was on the 2010 model). The 48mm Marzocchis are awesome but they must be sprung for the riders weight and ability. It also takes more break in time due to tight seals.
Old 08-21-2012, 08:41 AM
thumperrider1 thumperrider1 is offline
maybe there was an issue with the setup on those. The new 48mm Zokes are some of the best forks I've ever had. I didn't even have to touch the valving or anything. Just removed 15-20 CC from the outer chamber.
2018 XC300
2013 Pics Clay General Discussions & Announcements 105 01-05-2013 09:01 AM
2013 Models Clay General Discussions & Announcements 116 08-01-2012 12:58 PM
2013 300 US model Appalachian Offroad Pictures & Videos 2 07-30-2012 04:23 PM
New 2012 or wait for 2013 Diggs345 General Discussions & Announcements 76 06-25-2012 05:32 PM
2013 bikes imminent Diggs345 General Discussions & Announcements 36 06-19-2012 06:20 PM
