Old 11-10-2013, 03:31 PM
AZRickD AZRickD is offline
Wouldn't you know it, I'd be cursed again?
This time I took a slider in some loose doll head rocks in yesterdays tight-and-twisty hare scramble in Globe, Arizona.
I bent the shifter causing it to bind with the plastic stator cover. I had to coax the shifter to move back into re-set position with most shifts. I had 1st and 2nd gear reliably and occasionally a positive stab into 3rd.
I'll take it off, heat it, and try to bend it back into shape. I have spares, if need be.
Old 01-11-2014, 07:41 PM
TheLetterJ's Avatar
TheLetterJ TheLetterJ is offline
Sorry to dig up an old thread, but it was right on topic. My '01 EC300 got stuck in 3rd after stopping on a trail, no crash, no grinding, it was working fine and I shut it off to watch the kids run around for a few minutes and when I fired it back up it wouldn't shift. There was tension on the shift lever and it moved up/ down and returned to center, but still stuck in 3rd.
I took the side cover off and saw the "scorpion" stuck in the retracted position, a gentle tap with the back of a screwdriver and it was free. I don't see any wear/ grooves/ broken welds etc. so I'm concerned about why it stuck in the first place because I don't want it to happen again.
If I pull the shifter off of the shift shaft can I then just slide the shaft out (and reinstall just as easily) without internal parts coming loose? Looking at the parts diagrams, it looks like it should be that simple, but I wanted to be certain. I'd like to polish all the small parts up to make me feel better... or should I just put it back together and pray to the moto-gods that it won't happen again?
Old 01-12-2014, 11:35 AM
Yes, it is easy as pie.
Take care to remove the dirt from the left side because you could drag some of that in, I suppose.
GG EC250 '03 - Stuck in gear Roosta Enduro Engine - 2 stroke 4 01-01-2012 05:18 PM
Help with stuck transmission Zhack Enduro Engine - 2 stroke 6 07-05-2011 07:49 PM
ec250 stuck in gear thelonius General Discussions & Announcements 22 01-10-2010 01:09 PM
stuck between a ec250/300 blitzem General Discussions & Announcements 9 10-03-2008 10:40 PM
Stuck Throttle? jeffd Pictures & Videos 7 01-24-2007 08:04 AM
