Old 06-05-2018, 04:07 PM
Neil E. Neil E. is offline
Exactly. It acts as an insulator so chain vibration on the slider doesn't get amplified by the swingarm. Do make sure your sprocket alignment and chain tension is correct. You should have only slight chain play when the suspension is compressed to the maximum tension point. This is when the swingarm pivot, front sprocket centerline and rear sprocket centerline are exactly aligned.
On some bikes it's easy to remove the shock for checking. Other guys use a strap to compress the rear suspension. The fastest way is to have two heavy friends compress the suspension while you check the chain.
2011 EC250E
Old 06-05-2018, 06:36 PM
Chain slap for sure. All great advice above, or just live with it and keep the revs up a bit higher. Only time I really hear my chain slapping is on transport sections when I'm putting along.
Thread Tools
Display Modes
News flash. Chain slap noise fix!!! gasgasman Enduro Chassis & Body 10 05-23-2017 06:27 AM
Cam chain Slap - FSE 400 lukemillar Enduro Engine 4 stroke (including EFI & Exhaust) 11 08-25-2009 10:57 PM
power valve rattle not chain slap gasgasandrew Enduro Engine - 2 stroke 47 06-11-2009 05:24 PM
Chain Slap Malcolm Enduro Chassis & Body 4 12-04-2007 05:05 AM
clutch rattle? jostby Enduro Engine - 2 stroke 0 02-25-2007 05:01 PM
