Does this sound come from clutch or powervalve?! Help??
Need help fast!! Looped a wheelie with my 2013 EC300 and the engine started making some rattling noise or whatever it is called. It seems to come from clutch but IDK?? I opened the clutch and clutch case and found nothing suspicious! I got no idea what could be wrong since everything looked OK. Listen to the video please! It's in the link below
Thanks! https://drive.google.com/file/d/1VBR...w?usp=drivesdk |
I am no expert, but it sounds like some piece of plastic is vibrating (rad guard, side panel, skid plate). Try pressing on a few things while revving and see if that fixes it.
Almost sounds like the kick start gear hasn't fully retracted and is dragging against the idler gear. The only way to know for sure is to pull the cover.
WildAzzRacing YouTube channel Trail Riders of Southern AZ club AZ State Parks OHV Ambassador '11 EC250R '98 KDX220 |
^^^What he said.
I can't say I've ever seen my kick start move around when revved up like his in the vid.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
Thanks a lot for the replies!
I tried looking around for loose parts while revving but nothing was loose. Could be the kickstarter but don't know. I took the whole clutch case out but didn't really inspect the kickstarter yet. I'll try to rebuild the kickstarter and clutch and see if the noise still continues. Kind of weird that it started making that noise right after the wheelie crash. Didn't really expect anything else but plastic/silencer damage. But great to see that this site could actually be helpful! |
I think I moved it with my hand haha, I don't know why though. Or maybe I didn't?
In the video, you can see where you were holding the lever before it popped back.
The return spring would be weak. |
Is the pipe tweaked and touching/vibrating off of the frame or engine somewhere?
An easy way to tell if it is the pipe is to put your foot on it an put pressure on it to keep it from rattling.
does that sound ok to you | bonkeye | Pictures & Videos | 11 | 04-12-2016 09:32 PM |
Jetting, How does this sound to you? | memphis2857 | Enduro Intake/Carburetion - 2 stroke | 2 | 03-19-2015 03:23 AM |
Sound in clutch....hmmm | BluegassXCR | Enduro Engine - 2 stroke | 2 | 10-18-2011 01:59 PM |
clutch howling omg it's broken sound | MrBlah | Enduro Engine - 2 stroke | 6 | 10-04-2011 11:48 PM |
That sound never gets old! | Rick | Pictures & Videos | 6 | 05-21-2010 12:48 PM |
