Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 01-12-2011, 09:38 PM
matt_tidball matt_tidball is offline
Mine stuck once, but I use it all the time while WFO in a wash. It is nice to richen up a bit when I feel the need. Now I know how it feels when the problem happens, and all I had to do was pull the lever a little harder to make it unstick. For now I'm keeping the lever.
Old 02-12-2011, 10:43 AM
AZRickD AZRickD is offline
What is sticking? The internal cable itself? Not enough spring to get it back?
Or is the cable housing slipping out of the nipple?
If the latter, I would try safety-wiring it in place.
Old 03-16-2011, 04:41 AM
My bike has also recently developed similar problems with the bike running fine on low revs, then spluttering and just not getting into powerband properly
So i stripped the carb and cleaned it out properly checked float level, but now i am suspecting that the choke is getting pulled out and not closing.
As i am not in the US how can i convert back to a normal choke on the carb?
2003 txt250 Pro
2013 Ossa 280i
Old 03-16-2011, 06:07 AM
nambo-trev's Avatar
mine was always getting stuck half open and was getting quite annoying so i went back to the carb mounted choke as well
trevor
Old 03-16-2011, 08:39 AM
toolmaker toolmaker is offline
I bought a regular choke from Carb Parts Warehouse in Cleveland, Ohio. 216-635-1099. Cost me $25.00. Just unscrew the cable operated unit from the carb and screw in the new choke. You don't have to modify anything and you still have the complete cable unit if you want to go back to it.
Old 03-16-2011, 08:59 AM
gasgasman's Avatar
I was thinking that would work. Thanks for verifying it.
Old 03-31-2011, 12:22 AM
Tlineman Tlineman is offline
Sudco sells them too, also around $25
Old 05-08-2011, 07:11 PM
gasgasman's Avatar
I got a choke knob from BikeBandit.com for $16.41
Here's the ordering info......
"PLUNGER, STARTER
1193092 (282891-001)
Yamaha 2006 YZ250V YZ250 CARBURETOR "
Old 05-09-2011, 09:43 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
"PLUNGER, STARTER
Excellent. Thanks for posting.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
choke cable help???? nambo-trev Enduro Intake/Carburetion - 2 stroke 2 08-27-2010 09:23 AM
Cable choke for 03 250? marjastaja Enduro Intake/Carburetion - 2 stroke 3 02-28-2010 09:45 AM
Choke will not stay pulled up forgiven General Discussions & Announcements 10 09-05-2009 12:58 PM
Leak from around choke PEB Enduro Engine - 2 stroke 0 08-16-2009 10:16 PM
