Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 09-06-2018, 01:59 AM
Default Jakes Clearance Parts
Gas Gas folk,
I'll be having a sale of sorts. Parts are located within Australia so not sure how overseas postage will go price wise. I'll probably edit this post a few times updating what I have, what I don't, what other things I find.. and as I decide what prices I feel are fair.
So far we have..
TTX Inserts (I'll insert kit number) to fit Sachs OC 48mm legs. All parts included (carts, .46kg/mm springs, documentation). Recently serviced.
TTX Shock spring 5.6kg/mm available.
More to be added.
Old 09-10-2018, 12:56 AM
Sorry I haven't updated the listings with part numbers and documentation, or pictures. I'll try and get onto it tonight.
Just off the top of my head I also have the following.
2013 EC seat pan, foam and cover both showing wear across the knee area.
Motoseat seat cover to fit. I imagine it would fit 2012-2017 models. AS NEW; never fitted.
2014-2017 brake lever, bushing, etc. Retrofits to 2012-2013 models to sit outside the frame rather than snaking between the frame and cases. NEW; never installed.
2010-2011 Fuel cap. NEW
5.4kg/mm spring to fit Ohlins 888 (will add measurements).
2011 EC front fender.
2010 EC300R cylinder and head (need to add hours used, believe under 150hrs)
Red anodized S3 stars head, various inserts (250cc: silver/300cc red/silver/black).
Complete set of white plastics for 2013 EC; upper and lower radiator shrouds complete with OEM stickers; includes headlight shroud, rad shrouds, side number plates, front fender, rear fender, and fork shrouds; ALL NEW
Old 09-10-2018, 01:20 AM
shawbagga's Avatar
I'd grab the headlight shroud if it hasn't sold in next few weeks & ya wanna separate.
'18 Gasgas XC250
Old 09-10-2018, 05:19 AM
It's sitting on top of my 2018 fender at the moment shawry! Bit different to the newer ones (hasn't got the channel for the brake lines). Was tossing up putting it on but may just run the headlight yet.
Might end up throwing the whole plastics kit onto the 13 before I move her yet too. Options options.
Old 09-10-2018, 11:27 PM
Shiny bits..
Ohlins FGGG 12830
Fits: EC 250/300 Sachs fork 2009-2012
Showing some wear on the spring perch bushing. I have replaced them once while in use. Haven't been used in ages. Carts bled up well however low on N2 pressure at present, but will put 5 bar into them prior to going to a new home.
.46kg/mm Genuine Ohlins springs also to go with.
Old 09-11-2018, 01:38 AM
Thompo Thompo is offline
Price for the jug and head?
Rode my mates 300 and liked it
Old 09-11-2018, 02:07 AM
Shoot me a PM with an offer with the specifics. Cheers
Old 09-11-2018, 09:55 PM
What shock did ohlins replace? Would it fit my Sachs version? And how many $
Old 09-11-2018, 09:58 PM
Cylinder has around 150-160hrs run time on it, so it's done a bit of work. Sorry pics don't show the coating very well. All in tact, still crosshatching visible in areas.
S3 Head and 3 inserts
Black insert appears to have a small mark in the squish band, from being in storage.
Is very nice!
OEM head
Old 09-27-2018, 05:12 AM
I still have some parts!
powervalve spacer clearance Adam500 Enduro Engine - 2 stroke 6 04-13-2017 07:47 PM
Clearance with a smaller silencer celler Enduro Engine - 2 stroke 2 03-04-2013 09:36 AM
Graphics Clearance Harry Enduro Chassis & Body 1 11-26-2012 09:29 PM
powervalve clearance jeffs2200 Enduro Engine - 2 stroke 13 08-31-2012 10:44 AM
