Old 03-26-2020, 11:21 AM
Tony625 Tony625 is offline
Default 2004 EC450 crank no start
2004 EC450 crank, no start
I have an intermittent no spark issue. 12.4v at battery. Drops to about 11.5v cranking. Primary and secondary resistance within spec for ignition coil. 10v present at connector for coil when ignition on (shouldn?t that be batt. Voltage..?). When cranking .9v present at connector for coil when unplugged. Am I looking at a possible ECU issue?
Old 03-27-2020, 09:36 PM
Gasser Nate's Avatar
Those bikes were plagued with electrical issues, most of which were due to the ecu connectors and the fragile thin wires that connect to them. I have never seen a faulty ecu for one yet. Sold about 5 of them though, despite me saying it won?t be the issue.
450 fse 2004 help no start flam66 Enduro Engine 4 stroke (including EFI & Exhaust) 13 04-08-2017 01:41 PM
EC450 -10 wiring Svippen Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-10-2016 05:19 PM
2004 fse450 backfires and wont start jethro Enduro Electrical & Wiring 5 06-02-2015 01:22 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
09 Ec450 Wiggy Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-27-2009 09:33 AM
