Old 05-13-2023, 01:37 PM
Trailrider Trailrider is offline
Default another kickstarter question
Sorry it took so long. I just today got the broken kickstarter off the kickstart shaft. I do not recommend this but when nothing else worked we did the following: remove exhaust, remove carb, beat the knuckle with a pipe stuck through where the carb was. This took extensive beating with a hammer on the pipe. It finally came off. Now to order a new kick start lever.
Trailrider
Old 05-14-2023, 03:24 PM
Zman's Avatar
Zman Zman is offline
How do the splines on the shaft look?
Old 05-14-2023, 04:10 PM
Default Another kickstarter question
The splines on the kickstart shaft look good except for a small nick from the Dremel. The splines on the knuckle were shredded, I ordered a replacement, a Tusk brand lever
Trailrider
Old 05-14-2023, 07:58 PM
(F5)'s Avatar
(F5) (F5) is offline
What a good result. However check that the lever engages without slop when done up.
As I think I said I made a thick washer with an undercut so it pushed the lever on a bit further than a flat washer did.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 05-19-2023, 07:45 PM
New kickstart lever going on in the morning. (Sat)
Kickstarter gasman88 Enduro Chassis & Body 11 04-12-2018 10:52 AM
kickstarter question mxdad316 Enduro Engine - 2 stroke 5 05-01-2011 11:00 PM
kickstarter mikevancapel Enduro Engine - 2 stroke 10 12-31-2009 07:04 AM
Kickstarter Triple W Enduro Engine - 2 stroke 1 07-31-2008 05:01 PM
Question about YZ Kickstarter KicksonR66 Enduro Engine - 2 stroke 3 08-24-2007 03:01 PM
