Old 05-16-2018, 07:16 PM
rvktm rvktm is offline
Default clutch rivet size help and will it fit my 013
a while back i brought a clutch basket with gear of a gg 250 it has a date stamp of 08 on the basket all the rivets have bean drilled out any one no the size of the rivet , the hole size is 4.2 can i use 1/8 mild steel rivet .also will it fit my 013 300 thanks
Old 05-17-2018, 06:47 AM
I believe standard pop rivets will not work. I would tap the holes and use screws with Loctite like everyone does for aftermarket baskets.
Old 05-17-2018, 10:18 AM
sorry forgot to say its a gg std basket
Old 05-17-2018, 01:22 PM
I think it is still common for people to tap threads into the stock basket and use bolts to put it back together.
Old 05-23-2018, 07:07 AM
Thompo Thompo is offline
I used "Reaper Rivets" from a farm shop on a husky I was restoring. I think they are used for holding flail blades onto something, close to 5mm Dia, 20mm long and just cut them down to right length.
I struggled to find the right Dia/length/CSK combination anywhere. Rivets are mainly an aviation thing these days 100/130? csk angle.
5/32 would be a better fit for 4.2mm hole, ideally you would want a 4mm metric rivet. Remember to get a rivet long enough to allow proper forming of the head, typically stack thickness +1.5x dia.
There should enough material to open up the hole a little to allow for a bigger rivet or re-cut the csk to suit something you can get.
EDIT#Never been inside the gasgas clutch so not sure how the rivets are....
Old 05-23-2018, 12:35 PM
iv found 1/8 cks rivets on uk ebay only 3.00 uk for 10
Clutch fiber and steel size??? 2011 GG EC 300 jb250xcf Enduro Engine - 2 stroke 2 11-05-2016 05:16 AM
Magura clutch MC size on 2012 XC300? Bandit9 Enduro Chassis & Body 2 11-05-2013 07:01 AM
Clutch lever doesnt release clutch as soon as motor starts cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-19-2012 08:59 AM
Masterlink...Rivet or Clip Rick Enduro Chassis & Body 9 11-27-2009 07:17 PM
