Old 04-04-2018, 08:54 AM
3beejay3 3beejay3 is offline
Default Suggestions for waterproof e-start button
I have 2012 EC250 with E-start. The e-start button that GG uses isn't fully waterproof, so the contact disc gets rusty every so often, rendering the button non-functional. I then have to disassemble it, clean it and put everything back together. I'd like something that's a bit more robust and fully waterproof.
Does anyone have a suggestion of a good heavy duty waterproof moment switch that would work for this?
Old 04-04-2018, 09:14 AM
Anders Anders is online now
For a kill switch, I use a chinese type thats integrated in the brake pump perch. It has proven OK so far, I guess I have used it for between 50 and 100 hours.
I presume you could use the same as a starting button.
https://www.ebay.co.uk/itm/Universal...0AAOSwdjRasAi1
Old 04-04-2018, 12:05 PM
Wimpy525 Wimpy525 is offline
These guys have some great options:
https://www.highwaydirtbikes.com/ind...ow&ref=HDB-400
Start/Stop Button bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-21-2016 01:19 AM
Start button quits intermittently earlystock Enduro Electrical & Wiring 4 10-15-2014 01:20 PM
2012 EC250 e-start not starting on ze button! robszombie Enduro Electrical & Wiring 0 08-28-2012 11:42 AM
Bike won't start - suggestions please. stay_upright Enduro Engine - 2 stroke 22 04-28-2011 01:27 PM
Waterproof Pants PEB General Discussions & Announcements 7 02-21-2008 11:21 PM
