Old 10-04-2013, 11:56 PM
Coby_p Coby_p is offline
Default 2011 ec200 six days
Does anyone have an issue with there carb sitting on the engine case
Old 10-05-2013, 01:39 AM
What model carb? any pics?
Old 10-05-2013, 05:42 AM
hannesd hannesd is offline
don't overtighten the clamps on both sides and it'll be fine.
otherwise it'll just suck false air.
Old 10-05-2013, 11:10 AM
roverhybrids roverhybrids is offline
I've got a 2011 200 also with the AS1 round top carb and it also touches
I've got a 2005 300 engine with the AS1 carb and it also touches
2011 GasGas ec300R
2011 GasGas ec200 Six Days
Old 10-05-2013, 03:26 PM
Thats what I was thinking. Deeper bowl on the AS1. The clearance is pretty minimal on my 2010 250 with the AS2.
Old 10-06-2013, 09:30 PM
Does the JD jet kit work well with gas gas model bikes? or am i going to have to mess around with it a lot?
Old 10-06-2013, 11:16 PM
The blue needle should work really well with the AS1 in a 200/250. The needles are the same across the kits too so if you know anyone with a ktm/husaberg who is using a red needle, might even be able to pick one up cheap..
Old 10-18-2013, 11:22 AM
Switched to v force cage and now it has tons of clearance
Old 10-18-2013, 09:10 PM
be interested in hearing how the V-force performs.
2011 GasGas ec300R
Old 10-23-2013, 02:28 PM
Well i can't compare it to the stock cage because when i bought the bike one of the reeds had a chip missing about the size of a thumb nail, which i discovered after the first ride. However i can tell you that the vforce cage will theoretically allow much more flow because it has 4 reeds instead of two. I'm assuming its like a four stroke having more valves.
As for the first ride with the 200 fully functioning with the vforce reeds, the motor is pretty awesome, it has excellent mid range. The only issues i would have are when going up a hill once the power started to come in, the rear tire would light up. I later figured out that i was running way too much air in the rear for mud but i only remembered to check once i was back from the ride.
2011 ec200 Six Days $3900 roverhybrids Used Bikes 15 10-03-2013 03:25 PM
New 2011 EC200 Six Days Owner TEricksen General Discussions & Announcements 48 05-08-2012 03:22 PM
what gearing for 2011 ec200 six-days? roverhybrids Enduro Chassis & Body 4 04-12-2012 03:42 PM
