Old 01-17-2021, 05:09 PM
Gas Gassin's Avatar
Gas Gassin Gas Gassin is offline
Default Kickstart ratchet pinion and kickstart spring alignment for tension question
Hi y'all, I'd really appreciate some advice on this. I am replacing the kickstart ratchet pinion and kickstart spring on my 2002 EC 300. I have a question on kickstart ratchet pinion and kickstart spring alignment to get the proper tension from kickstart spring. Can someone tell me the placement of the kickstart ratchet pinion when placing the ratchet lever between the plate and the case and the kickstart spring should be to start in relation to the location of the spring arm starting location? I put a picture of how the spring was when it was pulled free from the hole and it was at rest free. Is this the position it should when the kickstart ratchet pinion lever is between the plate and the case?
Old 01-17-2021, 07:37 PM
Gasser Nate's Avatar
Cool
Normally with the ratchet arm turned clockwise against its stopper it is about half to a quarter of a turn to pull the return spring around to its hole.
Most manufacturers have an alignment mark but for some reason Gasgas thought they could save some weight...!
You will know if you have too little or too much tension on the return spring.
Old 01-20-2021, 08:52 PM
And for reference, this is where I set the spring at rest. Took some effort to bring it right around but the kicker recoils all the way as expected.
kickstart question imsimon Enduro Chassis & Body 1 02-01-2017 01:44 AM
Kickstart spring size? motopsycho87 Enduro Engine - 2 stroke 2 11-17-2014 03:20 AM
Kickstart Knobbly United Kingdom 4 03-25-2013 02:13 PM
Ratchet spring. Ud_luz Enduro Engine - 2 stroke 1 05-12-2009 07:40 AM
Kickstart shaft question GMP Enduro Engine - 2 stroke 6 02-22-2009 02:55 PM
