'13 300 jetting and plug? S2 head/cylinder
I've never had a bike that was unjettable!
The motor has 4-5 hrs since new and has an hour on the new S3 cylinder'head combo, no seal leaks, 98 leaded fuel, CR7 plug(installed from dealer), float correct, 50:1 full synthetic mix, 152 main and 35 pilot, clip on top notch... Bike runs VERY strong mid to top but has more spooge/plug is wet. I just added a gnarly pipe to pull the power down lower in the revs - has not been ridden since install. The only issues I question is the ignition switch(sun/cloud) was partially(1 wire) chewed by my favorite field mouse and the CR7 plug... it seems odd running such a cold plug, thought either a CR8 or BR8 would be the correct range to run... I can't find a pilot under a 35 Thoughts??! |
Gas Gas oil filler plug with 13mm wrench head | Buddmatto | Parts | 5 | 02-01-2018 08:24 AM |
Setting Squish on an off centred plug hole head | savage sausage | Enduro Engine - 2 stroke | 8 | 08-11-2016 12:30 AM |
Swopping 1997 Cylinder head with 2005 head | EC250 | Enduro Engine - 2 stroke | 10 | 12-15-2015 10:13 AM |
Coolant leaking through cylinder head socket-head bolts. | GGRider01 | Enduro Engine - 2 stroke | 5 | 10-17-2015 07:38 PM |
Magnetic hex head oil drain plug crossover?? | eaze_50 | Enduro Engine - 2 stroke | 26 | 05-13-2014 07:08 AM |
