Old 08-14-2013, 01:56 AM
Packman Packman is offline
Default 2004 300 ec idle setting ...
What is the best way to up the idle on my 04 300 ec. It now stalls off the throttle and desending while in gear witch does my head in .....
Do you do it on via the cables or screw on the side of the carb ?
Old 08-14-2013, 02:05 AM
The large plastic/brass screw with the spring behind it is your idle speed. It manually lifts the slide. If you find the spring is bound up and its already turned in almost all the way then its likely the needle/pilot circuit is rich and thats the cause of the stalling.
Old 08-14-2013, 03:32 AM
Yes the spring behind the screw is coil bound. How do i rectify the problem ?
Should i drop the needle 1 notch ?
And thanks for the reply ....
Old 08-14-2013, 03:50 AM
Best advice I can give is to pull the carb down and have a look at whats in there now. Then you'll have options on where to go. Also, check the sticky jetting database in this subforum and see what others were running in 04 models. I've got no first hand experience with the earlier years so aren't much help in that regard.
Old 08-15-2013, 05:38 AM
Ok will pull the carb this weekend. I know jetting has a lot to do with sea level as well so id say im at 0-500 feet.....
tourque setting bonkeye Enduro Engine - 2 stroke 3 11-24-2012 05:07 PM
ec 300 setting correct pilot jetting, idle low end hillbilly Enduro Intake/Carburetion - 2 stroke 5 07-08-2012 10:28 AM
gasgas 2004 end f@@k idle Gasgasogeros Enduro Intake/Carburetion - 2 stroke 3 06-30-2012 03:58 PM
Sag setting question Synergy-Seals Enduro Suspension 4 10-25-2011 04:40 AM
Setting up my EC300R 09 Keg General Discussions & Announcements 4 09-27-2008 07:42 AM
