Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Ride Reports
Ride Reports Tell us all the gorey details!
Old 05-03-2008, 12:59 PM
tm_enduro's Avatar
tm_enduro tm_enduro is offline
Originally Posted by wannabe View Post
As far as the rims go, I've been working with about 3 different companies and all have different opinions and thoughts on the GasGas Hub...all have not quite worked yet, but I'm close to a solution and hope to have complete aftermarket wheel sets available in black, red, blue, or silver within 2-3 months for about $725 retail including rotors and sprocket.
The Rad set up was a KTM front hub with a KTM rotor and special spacers. The rear hub was a early 1990's Honda hub with special spacers, honda sprocket and honda rotor from the early 90's as well. It worked ok, but the rear rotor was a 4 bolt rotor and I'm not too fond of that.
$725 for a complete set of wheels with all parts is a pretty good deal. I agree that using GasGas parts is preferable, since the next owner might not be so keen on finding parts for a "Franken-bike". Keep us posted.
By the way, I appreciate it when the importer takes the impetus to find aftermarket part sources for a brand that fill a void that the aftermarket mfgs would not go after.
Old 05-03-2008, 06:41 PM
widebear's Avatar
widebear widebear is offline
Banned
Ive dealt with Jeff Roberto at east coast wheel, they built a 18 incher for my mc-250 using a ktm exel hoop. I was very happy with their services.
Old 05-13-2008, 11:22 AM
GG27 GG27 is offline
Originally Posted by widebear View Post
Steve. Re: push. Just curious what rear tire and size are you running on that bike?
Also the forks being up 3/8" and 105mm racing sag seem too much of a forward weight bias and the 7/8" static sag seems stiff.
I followed the instructions on setting sag on the sight (shock spring 10mm compressed) for my 2008 EC and ended up with the forks 2/8" up and 110mm race sag and 30mm static sag and really rails in the corners, never pushes. I have bars on the front triple clamp's holes. BTW I'm 5 11 and weigh 190 lbs.
My clickers are set at : Forks: Compression 17 out Rebound 6 out
Shock: LS compression 19 out HS 1 1/2 out RB 20
What clicker settings does the "R" have?
EC250 2008 Skid plate, rad braces, Fork bleeders
Drz 400 Motard '03 (full spec)
Yz 250 '06, KTM exc 250 '05, exc 250 '04, exc 250 '02
WRF250 '02, KDX 220 '98, DT200R '93 all sold
Old 08-16-2008, 02:23 PM
AZRickD AZRickD is offline
GG27, similar numbers here as well for sag.
Same weight but a little shorter so I'm on the back TT holes. I have my forks up 3/8" but I might move them down a bit.
I have my clickers almost all the way backed out (Arizona rocks).
Old 12-08-2008, 04:27 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Awesome mate,
Just bought my ec300 and was wondering what to set mine at for a starting point.
I am basically same height and weight and had already set everything close to what you have but think I will raise the forks through a little.
Cheers
F_G's son makes GoFasters.com "Race News" AZRickD Ride Reports 4 05-28-2009 09:46 PM
'06 EC300 Rear wheel "top-hat" bushing Eugene Enduro Chassis & Body 1 01-23-2009 10:27 AM
2008 "Racing" model gasgasman General Discussions & Announcements 16 09-21-2007 11:40 PM
Recommendation: add "Injury/Recover" and "Riding Techniques" sections MattR Suggestion Box 2 07-18-2006 09:19 PM
