Old 07-03-2009, 12:32 AM
Fire Escape Fire Escape is offline
Originally Posted by jefgil123 View Post
I know! I have in the past - "back bled" with syringe, foreward bled, and
still had sponginess...there must be air in the line anyways !
I have read of people taking the master cylinder off and hanging it so the
line is vertical, and tapping all along everything, and getting the tiny
bubbles to rise.
That is what worked for me when my front brake suddenly "dissappeared" just before going in for inspection. Hung it up on some welding rod overnight and it was "all better" in the morning.
Bruce
No one ever calls the Fire Department because they did something smart
Old 07-03-2009, 03:49 PM
einsteingarage einsteingarage is offline
Another solution to a problem similar to this is to check your piston, no not your engine piston but brake piston. If it has a lot of miles and has worn at an angle it will not push flat against the brake pad. You can machine it, or sand it flat and it will apply equal pressure on the pad eliminating sponginess.
Figured I would add this in case it gets a sticky
Brakes redrider7202 Enduro Chassis & Body 5 04-05-2010 05:45 AM
torquing cylinder base nuts.... stainlesscycle Enduro Engine - 2 stroke 17 03-08-2010 06:42 AM
VisionX Solstice LED driving lamps GMP Enduro Electrical & Wiring 11 01-14-2010 10:07 AM
Grabby front brakes rpduc Enduro Chassis & Body 11 05-28-2009 08:39 AM
No Rear Brakes!!!!! matt4wheels Enduro Chassis & Body 5 04-21-2007 02:06 PM
