Old 10-27-2018, 01:55 PM
BLD's Avatar
BLD BLD is offline
Default Stuck bolt, bent allen key, 2013 XC300 front brake rebuild.
Anyone have any tips to remove the small bolt pictured below. Went to split the calipers to rebuild the front brake and install new pads, and after a week of spraying penetrating oil, the only thing that moves is the allen wrench as it bends...
What should I use? Heat or an impact? I tried a pin torch (gas soldering iron), but no luck... Thanks!
File Type: jpg DCB1D0BE-77BF-489A-839E-336891FCE393.jpg (71.6 KB, 20 views)
Edit: I am done caring why my apostrophes always turn to question marks!!!...
Old 10-27-2018, 02:12 PM
john r b's Avatar
john r b john r b is offline
Default Pad pin bolt
Needle nose vise grips may help by gripping the pin,or cutting the pads out, in order to get a larger vise grip inside. a higher quality allen key will help too.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 10-27-2018, 03:38 PM
I ended up replacing the whole caliper on my 13 after I did the same. I drilled the head of the allen out and was able to remove the pin but at the same time damaged the threads a bit and wasn't happy with the result. Not a lot of room to open it up and drop a helicoil in either. I'm pretty sure I threw it in the bin as they are a dime a dozen.
I rounded it out using a quality socket and a old impact that you whack with a hammer. It was jammed and I wasn't patient enough.
Some heat will help, as will continuing with the oil. A bit of shocking can help allow the oil to penetrate, otherwise I would do as above. Cut the pads off the pin, and then use the full length of the pin to grab and turn. Even if you need to grind a flat side on it to get a good grip. You should be able to get it out without damage to the caliper.
Old 10-27-2018, 03:51 PM
BLD's Avatar
BLD BLD is offline
Wow, that is crazy! I got lucky by treading lightly with my impact. I put it on the lowest torque setting and went very slow with a 5mm bit. I guess some of the penetrating oil helped because it finally broke free wothout any issue. Bleeding the brakes now after replacing the pistons and seals, and a thourough clean up. Almost there, and the new pads do not drag on the disc anymore! Now to spend an hour in the manual finding my torque settings lol.
Old 10-27-2018, 04:13 PM
Davehuge's Avatar
Davehuge Davehuge is offline
That's good news, patience is a wonderful gift...I wish I had more sometimes!
Old 10-28-2018, 01:19 AM
Anders's Avatar
Anders Anders is online now
If this is the pin that holde the pads, I have had success with the following prochedure :
Cut off the pin with a hacksaw two different places. Knock out the part without threads with a suitable drift. Pick out the pads. Now, you have access to the threaded part of the pin from both ends and can use vice grip pliers or allen key or both, in combination with heat and penetrating oil.
In my case it was very easy to get the threaded part out when the other end of the pin was knocked out.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 10-28-2018, 03:59 AM
Davehuge's Avatar
To prevent it happening again, apply a thin smear of copper grease to the threads (also known as anti seize compound) then wipe away any excess after fitting.
Old 10-28-2018, 07:22 AM
Anders's Avatar
Attachment 7883
And not only to the threads. The other end is also prone to seizing
Anders
1986 Duc Mille S2
etc
Old 10-28-2018, 07:37 AM
Davehuge's Avatar
Yes, good idea.
It's great stuff, I use it all the time on my bikes and car, even my lawn mower! It's so nice when you come to removing anything.
*Protects metal against corrosion, heat and water
*Withstands temperatures of -40C to +1150C
*Does not wash or burn off in normal use
*Suitable for use on wheel nuts & bolts, exhaust brackets, flanges & studs, etc.
Stuck front brake pin Trailrider Enduro Chassis & Body 8 04-26-2018 10:01 AM
Front brake master cylinder rebuild kit Joper Enduro Chassis & Body 0 03-17-2018 01:25 PM
PV Allen bolt stuck Shooter Enduro Engine - 2 stroke 5 04-05-2015 03:23 PM
Banjo Bolt - Front Brake M/C JP4 Enduro Chassis & Body 10 12-04-2013 09:54 PM
Rebuild kit for '06 EC 300 Nissin front brake MC? brider Enduro Chassis & Body 0 03-10-2013 10:30 AM
