Old 05-11-2019, 07:26 AM
Mikeyx Mikeyx is offline
Thanks for your help.
Now all mounting points as well as rear subframe fittings have been tightened. There was only one point which was not more or less loose.
Old 05-13-2019, 06:31 AM
jprizz jprizz is offline
I also suggest you check to see if the upper engine mounts are cracked. (The ones at the top of the cylinder) I had one cracked in half and my engine made quite the racket and vibrated a lot with it broke.
-Josh
2009 EC300 Six Days
Old 07-11-2019, 06:26 AM
Well, well, well... Mechanical noise came back, and I found that two mount nuts were loose again.
I suppose that I need to secure the nuts w/ a threadlock fluid?
Will a medium strength be sufficient? Any other pointers?
Old 07-11-2019, 06:38 AM
risk74 risk74 is offline
As said above, check the head steady bolts and tie bars. I've cracked/worn out several of these as well. Also, if the aluminum mounting plates that swing out when the swingarm bolt is removed are worn out, no amount of tightening is going to solve this problem. I have had to replace a few of these over the years and also had to put shims in when the engine cases got wear at the bosses as well.
Once that lump starts vibrating and moving around in the frame like that, things wear out quick. One hour into a three hour enduro several years ago, my engine started vibrating and making a racket, figured crank was going and keep racing. By the end of the race I had worn a hole through the cases from the movement, trans oil leaking everywhere. Now I routinely check all related engine mount/suspension bolts. Saves a lot of headache later.
Broken Engine mounts: 2011 EC300 :( fenwickwick Enduro Engine - 2 stroke 17 02-25-2015 10:36 AM
engine mounts on ec 300 2013 mikhogl Enduro Chassis & Body 2 04-25-2014 10:38 AM
EC200 Engine Mounts Jakobi Enduro Chassis & Body 3 10-24-2012 05:56 PM
Engine mounts on to frame west aussie gas 450 Australia & New Zealand 3 01-28-2007 08:16 PM
engine mounts on to frame west aussie gas 450 Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-26-2006 08:59 AM
