Old 06-29-2019, 03:26 PM
Mc_Grath Mc_Grath is offline
Default Shifter shaft getting play
Hi all, I have a 2019 EC, it has 1200 km aprox... Anyways, I noticed the shift shaft had some play, it was not the pedal but the axle itself twisted and allowed the shifter move up and down (the spring only returned the pedal half way).
So I removed the clutch pack and found that bushing n? 18 in the attached diagram was separated from piece 20, allowing piece 20 to move around a little bit instead of pivot over piece 18....
So I installed it again, put everything back toguether and shifter is perfect, Zero play..... After 2 hours riding, free play is back, 18 and 20 must have dettached again.
Anyone has this happen before? I had ordered 18 (wich is a nylon bushing), but i am not sure that will solve it as the original one looked perfect and had no play once is was installed correctly
https://www.motocrosscenter.com/shop...50236041.html#
Help crank shaft play andrewjtheis Enduro Engine - 2 stroke 10 05-15-2019 05:56 PM
Shift shaft play Stamper Enduro Engine - 2 stroke 4 01-31-2016 05:20 PM
shifter shaft c-clip flybars Enduro Engine - 2 stroke 3 03-09-2010 05:36 PM
Waterpump shaft end play SpeedyManiac Enduro Engine - 2 stroke 1 04-08-2009 09:05 AM
