Old 08-03-2020, 12:52 PM
Neil E. Neil E. is offline
You must have the estart model. It uses a DC powered CDI, so the "single winding" wires are not connected to anything. You should get a high AC voltage on the two wires going to the rectifier. If not the stator may be bad. Clean and grease every wiring connection. Clean every ground point then try running the bike and checking AC voltage out of the stator. If it's high (50-60 volts), then check the DC voltage out of the Reg/Rect. If low you need a new Reg/Rect. If your battery voltage drops low enough the CDI may start misfiring.
Download the 2014 GG enduro manual. It has wiring diagrams in it.
Old 08-03-2020, 01:23 PM
GasGasRider_ GasGasRider_ is offline
Thanks i will check this, but one question. I have stator like this on my bike https://www.motocrosscenter.com/shop...058209101.html can i put different one on bike like this one https://www.enduropuro.it/shop/en/el...300-00-13.html
Old 08-03-2020, 07:11 PM
The units on those listings appear different, but someone else may be able to advise you. I don't know what differences exist on the newer machines. If you search a bit you can find topics here that show how to install a common KTM stator on the GG mounting plate. A little modification to the wiring connectors is required. Here is a photo of the 2011 stator. Note the number of windings.
Old 08-04-2020, 06:14 AM
I was check possible solution. AC voltage from stator is 50-60V on normal throttle but on full throttle is 80/90V. Is this ok or to high
Old 08-04-2020, 12:22 PM
Don't get too concerned about the actual AC voltage. You are measuring it with only the tiny load of a multimeter. Under normal conditions the regulator/rectifier will clip the excess voltage. The actual DC voltage output should be anywhere from 13.8 to 14.8 volts. Try a new R/R and measure the DC output.
Old 08-11-2020, 01:14 PM
Hi guys, i solve my problem, the problem was reg/rec.
Thanks everyone for help.
Old 08-12-2020, 03:43 AM
(F5) (F5) is online now
Sweet. Glad you got it sorted.
Bike won't run without battery and won't charge battery memphis2857 Enduro Electrical & Wiring 3 04-28-2017 09:02 PM
Battery problem? tzsuzuki Enduro Electrical & Wiring 12 01-20-2016 10:18 AM
I bought a 2000 xc and keep finding problem after problem 675AZ Enduro Engine - 2 stroke 12 02-15-2013 07:25 PM
Battery for a 07 450? fastisbetter Enduro Electrical & Wiring 2 03-29-2011 08:06 PM
battery power problem GalenaGasGas Enduro Electrical & Wiring 3 04-15-2009 03:06 PM
