Old 04-16-2020, 03:14 PM
rvktm rvktm is offline
Default ec 250 power valve governor what year gg did change from 4 ball to 6 ball
my history with gg is new 97 new 98 had a go on a 99 hated the power to mx no balancer[ loved the 98s two bikes in one power stupidly sold it to a mates son in 016 hope to get it back soon ] then they fitted wp forks 02/03 had a go on a 02 300 to much for me . got a new 05 ec 250 loved the handling but the power was soft .in about 06 a mate gave me a trusty adjustable pv cover the difference was night and day better .always though that the power was a bit flat .in about 016 was told to remove the reed spacer had to use a 98 250 boysen valve that got the power i wanted . then i got a 013 300 sopped the trusty pv cover over to that then it got stolen just over a year ago so back on the 05 with no trusty iv fitted a flywheel weight better suzuki needle not that impressed liked the n1eg i only ride in woods no mx . so now im looking at the power valve gov .just got one of a 98 ec of ebay it only has 4 balls not 6 . looking on gg parts book [only go back to 2000 ] there 6 ball . thinking less balls slower opening better mid range power? looking at the 015 on adjustable pv the ball ramps are in the gear the shaft has a 5m screw the pin sits in a slot so you can change tension on the spring . tempted to get a 015 shaft and see if it will fit my my pv set up only ?20 .the problem i can see is that it will lift the pv open when i wined the adjusting screw in any one got a 015 pv gove to hand need slot placement .thanks
Old 04-16-2020, 03:26 PM
gasgasman's Avatar
The weight of the balls is what determines the opening rate.
6 balls just spreads the load out evenly.
Old 04-16-2020, 04:17 PM
they look the same size balls as the 6 ball type .
Old 04-16-2020, 05:49 PM
Zman's Avatar
Zman Zman is offline
You can change the shims to reduce or increase the spring force on the balls and power valve activation rpm.
Exhaust Valve Governor Assembly mcnut Parts 3 11-13-2015 10:36 AM
Ball bearing in fuel tank? roostafish General Discussions & Announcements 5 03-03-2011 06:01 AM
power valve ball retainer thingy skid jackson Enduro Engine - 2 stroke 7 09-30-2009 03:32 PM
Gasser have found the ball TooFastTim General Discussions & Announcements 2 08-04-2008 02:56 PM
