Old 09-02-2020, 01:18 AM
Sdogg Sdogg is offline
Default 2017 ec300 choke issues
Gasgas newby here. Loving it so far but still learning! Has anyone else had an issue with the choke cable being to short so that the choke was constantly held at a partly open position? I have recently purchased an 2017 ec300 and am just ironing out a bunch of small issues I have had with it, mainly carb related. So ended up figuring the choke was staying partially open causing various issues of course. Seems there is no adjustment from the lever to the carb, thought outer may have been stretched somehow but this doesn?t appear to have happened. Ended up machining the plastic nut at the carb end to allow it to screw in further and let the choke seat properly. Wow what a difference!
Old 09-02-2020, 01:24 AM
Anders's Avatar
Anders Anders is offline
Hello, and welcome to the GG world!
What we usually do is to remove the choke cable alltogether. Just replace it with a choke pull knob directly on the carb.
Something like this one, just make sure that you get the correct one for your carb.:
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 09-02-2020, 01:55 AM
[QUOTE=Anders;196214]Hello, and welcome to the GG world!
So I guess this is a common issue then?
Old 09-02-2020, 05:56 AM
Anders's Avatar
Yes, it is. The cable will get rusty and filled with dirt over time, and the choke will be unable to close / turn off. Poor running is the result.
Anders
1986 Duc Mille S2
etc
WTB: E-Start Kit for EC300 2017 mellllo Parts 1 10-09-2019 04:25 PM
WTB: E-Start Kit for EC300 2017 mellllo "Wanted to Buy" & "Want To Trade" 0 10-09-2019 04:22 PM
2017 ec300 buckmills93 Used Bikes 4 08-21-2018 03:52 PM
2017 GasGas Ec300 Jotkins52 Enduro Chassis & Body 0 02-05-2018 09:15 AM
2017 ec300 nelly001 United Kingdom 2 02-01-2017 04:20 AM
