Old 07-13-2016, 02:55 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Originally Posted by Lian View Post
Does put a Suzuki thrust washer 2.0mm instead of stock 2.8 mm under clutch hub make sence (clutch hub to basket spacer) when converting to a CR250R cluth plates?
We have hydraulic clutch that push long clutch rod (which push pressure plate), so if overall plates pack size is bigger than standard (34.5mm CR250 vs 33.3mm GG300), then after additional 2-3 pushing clutch lever that long rod will be pushed forward that extra 1mm and stay there forever.
So i don't understand how changing thrust washer are changing something?
Besides that - basket, plates and pressure plate is one whole assembly, which moving inside (in engine) when changing that washer to thinner one - so really nothing happens to compensate new pack height of CR250 plates. Only 6 springs are more preloaded (~1mm), but i see you never feel that after conversion.
Does the way of my thoughts right?
Even though the push rod extends outward to take up the slack in the operation of the clutch, the thinner washer gives more freeplay in the clutch pack setup; which can decrease clutch drag.
My first GasGas importer told me that the reason that clutch drag was a bigger problem in our bikes was that there was very little free play in the clutch pack. In effect, "The tolerances are tighter in the GasGas clutch pack."
The thinner thrust washer would help with that, by adding 1 mm to the free play.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 07-24-2019, 01:36 PM
Rampart Rampart is offline
Originally Posted by motopsycho87 View Post
So the clutch has 8 friction plates, and 7 steels...
Standard GG clutch
(2.85*8)+(1.5*7) = 33.3, where did 28.95 come from?
CR250R clutch
(3*8)+(1.5*7) = 34.5, where did 30 come from?
So 34.5-33.3 = 1.2, so if the spacer is originally 3mm, it should be reduced to 1.8, cool... BUT!
I have the same measurements.
BUT it sounds good on paper for me.
In fact, according to calculations, everything should work out.
In reality, i made spacer 1.5 mm, BUT nut pressed the hub so much, that it became one with the basket, and there can be no talk of clutch work. It looks like I need a 1.7mm spacer, BUT will the clutch pack fit?
Old 02-21-2020, 09:10 AM
Nicktamps Nicktamps is offline
Hi all. Looking at doing this conversion. From what I have read there are different ways of doing it. I've got a 15 ec250. What's the easiest way of doing it? Also does that stack height actually make that much difference. As I would have thought the slave cylinder would take the slack up?
Old 02-21-2020, 09:15 AM
Which part number are you all turning down?
Old 02-21-2020, 07:02 PM
Jim Cook's Avatar
Thumbs up
I can't answer your question directly, but I have no clutch drag on my 2011 EC250, and had no clutch drag on my 2006 DE300.
I accomplished this using the stock GG clutch components.
To accomplish this I did three things:
1. Made sure that the clutch hydraulics were completely bled of any air.
2. Made sure that the clutch master cylinder's actuation pin was not adjusted in to far and pushing the piston too far into the master cylinder. (this won't let the master cylinder self-bleed air while it's being used, causing problems.)
3. Started using 50ccc more oil than the factory recommends (1100cc on the '97-2000 models, and 1000cc on the 2001 and later models), and using Amsoil 0w40 synthetic Formula 4-Stroke Powersports Engine Oil in my transmissions.
When I was doing research for Rekluse, using their first generation auto clutch, i sometimes started my bike in gear without knowing it until I blipped the throttle. That led to some "picturesque" and very humorous to watch starting events.
This is some seriously good oil for your clutch and transmission. Plus, it stays pretty a lot longer than most other brands that I've tried.
https://www.amsoil.com/shop/by-produ...?code=AFFQT-EA
I hope this helped a bit.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 02-22-2020, 09:19 AM
Thank you very much. You have helped. I might just put a stock clutch back into it. Don't want to be messing about with it to much
Old 08-18-2020, 01:47 PM
MuddyArgyle MuddyArgyle is offline
Alright, I'm trying to go the opposite direction of most people in this thread. My 2011 ec300 had a rekluse core exp 1.0 on it when I bought it. I've been riding trials a lot lately and want to go back to a manual clutch on the gasser.
I have the rekluse basket, inner hub and pressure plate. I also have a gasgas pressure plate, but not the hub or basket.
One idea I had was to just take out the exp disk and put in new friction and steel plates. I talked to rekluse and they said I could do that, but I'd need to buy the core manual pressure plate, but that's $200 plus the cost of the steels and frictions. I'm not sure I'd actually need the pressure plate, as I could just adjust the core pressure plate. I'd still need to replace the steel and friction plates. Do these have to be from rekluse or could I use cr250 plates?
The second option would be to source the OEM parts and replace them, but that might be tough.
So, if I buy the entire setup for a cr250, would it be a drop in replacement?
In summary, here are my questions:
Can I use cr250 plates in the rekluse basket and hub?
Can I use the rekluse basket and hub with no exp plate, but more other plates?
Could I just drop in the entire cr250 clutch assembly (basket, hub, plates, etc)?
Old 10-07-2020, 12:40 PM
Update/bump on my earlier post...
I bought cr250 friction plates and tried to install them without the exp plate. The pressure plate is way too tall to use without the exp plate, so that idea is out. I may just have to buy the core manual plate for $200.
If I do that though, I'm worried the cr250 plates will be too thick to use that setup as is, and I'll probably need to get creative with some washers in there.
On the other hand, I could maybe just buy the stock setup and go back to that, but my real goal here is to have a manual clutch with good feel that I can reliably find parts for longterm.
Any input is appreciated.
Old 10-08-2020, 06:00 PM
Jim Cook's Avatar
Thumbs up
If you can't find the OEM GasGas plates, the Moose Racing steel and fiber plates look just like the 2006 OEM GasGas pieces. I believe that DunlopPad (Tony Mills Racing in the UK) made the plates for Moose, and maybe the OEM plates for GasGas during that time period.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 10-25-2020, 02:38 AM
LEON GORJAK LEON GORJAK is offline
Exclamation When I put in 1st(holding in the clutch) my bike jumps and stalls
Hello.
I have EC300 2018 and I changed my friction plates in the clutch and changed the oil in the clutch but the problem I described above still exist.(The oil in transmition is changed I put in 10W30 bel-rey oil)
The problem is there when the bike is hot and cold.
Thanks.
TXT 200 pro clutch.. jhendr3702 Other GasGas Bikes/Quads 1 01-28-2011 10:10 AM
Clutch problems gaser Enduro Engine - 2 stroke 5 11-15-2010 07:51 AM
Clutch going out? Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 5 07-30-2010 01:00 PM
450 clutch, same as DRZ? Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 2 10-01-2009 07:58 PM
What clutch oil is best? wence Enduro Engine - 2 stroke 5 08-20-2009 03:57 AM
