Old 11-25-2018, 12:35 AM
Neels Neels is offline
Originally Posted by CMSTAJ View Post
I was thinking it might be the piston or rings, but they and cylinder look ok.
Then we found that the bottom is still bound, shown in the second pic below.
Not sure what we are going to do from here, getting to this point is pretty good for us.
Evening sir. I hate to break it to you but your crankshaft is toast. Thrust washers are chewed up and one can see where there was excessive heat on that crank.
I'm not here trying to take your money please understand that, however I am a mechanic and would be happy to help you with the engine if you'd like me to. I see your in middle Tennessee? Is that correct? I'm in Franklin just south of Nashville.
My name is Neels and my number is 307 seven six three 317four. Text or call me and we could work something out.
Old 11-25-2018, 01:03 AM
(F5)'s Avatar
(F5) (F5) is offline
Been riding my 07 today. What a fantastic machine. Worth preserving.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-25-2018, 02:54 AM
RBrider's Avatar
RBrider RBrider is offline
My '01 XC 200 seized like yours . It turned out to be a bad left (or mag)side crank bearing. The cage for the ball bearings came apart and wedged between the crank & the cases.
It's a pretty easy & straightforward engine to work on, imo. Also, if you do a search on this forum, there's a very good step by step engine rebuild report posted. It's for a 250, I believe, but , except for using a different right side crank bearing, the same as your 200. I used it when going thru my 200. It was a great help.
Or, pull the engine and take it to Neels .
One other point. My GG owners manual says to use syn oil with prem. fuel at 50;1. That's what I use and it has worked fine.
RB
Old 11-25-2018, 03:24 PM
Harry's Avatar
Harry Harry is offline
My 300 seized under similar circumstances. Turned out to be corroded main crank bearings, the result of long term storage.
Old 11-25-2018, 04:54 PM
Here are a couple links to rebuild threads. Good spread of pics through both. Lots of tips thrown in by the knowledgeable folk.
http://www.gasgasrider.org/forum/showthread.php?t=21160
http://www.gasgasrider.org/forum/showthread.php?t=14730
Old 11-26-2018, 05:32 AM
CMSTAJ CMSTAJ is offline
Thanks for the help so far from everyone.
We are going to keep studying and post what we come up with for next steps.
Old 12-01-2018, 03:44 AM
We talked to a local shop here who works on gasgas (performance supercycle) close to Cookeville and they are doing some checking to see if the can find a total rebuild kit & the cost if they did it for us. Hope to get some info back next week.
We'll $ee...
pv breather 2007 ec200 jason tati Enduro Engine - 2 stroke 4 07-23-2016 06:23 AM
2007 EC200 - CDI Pinout Steve-A Enduro Electrical & Wiring 4 10-28-2014 04:50 PM
Chance of seize during road riding? Radbuster Enduro Engine - 2 stroke 10 10-17-2007 11:57 AM
