12 EC300 mapping question
Im using a multimeter to test mapping
One question about the mapping, when on sun mode ohm reads 1. when switched to rain mode it reads .7, this with the bike off. Does this reading mean my switch is okay? Is .7 enough? thanks! Nick
12 EC300 97 ATK 260 95 HUSKY TC250 99 CR125 92 KDX220 92 YT250 88 XR80 |
The "1." reading means isolation - no contact at all. ".7" I assume is 0.7 omhs which is probably the resistance in your probe cables. That is the closed, or ON reading.
I do think you might have a switch that is not meant for the Gasgas CDI. It should be closed (Your 0.7 readout) when in Sunny mode. Note that the switch should be flipped towards the sun symbol for sunny mode. Switch button is flat and level with switch body when mode is activated. Does that make any sense? |
gasgas wild 450 rev limiter / mapping questions | henke | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 07-20-2014 03:11 AM |
'06 ignition mapping switch | brider | Enduro Electrical & Wiring | 4 | 09-17-2013 06:53 AM |
Ignition curve switch wiring - Dual Mapping | smallpuffydog | Enduro Electrical & Wiring | 5 | 09-08-2011 02:04 PM |
ec 300 mapping | glassman581 | Enduro Electrical & Wiring | 2 | 02-27-2011 10:07 AM |
Dual mapping switch on 05 de250 | thelonius | General Discussions & Announcements | 3 | 06-01-2009 02:37 PM |
