2002 Gas Gas XC250 REbuild info/specs ?
My sons 2002 EC250 was locked up tight on Memorial day, kickstarter would not move, rear wheel elevated/in gear only slightly. Teardown revealed that a crank stuffer screw has backed out, wreaking havoc, ending a fine ride before it began, although the end result could have been much worse.
Looking up the crank stuffers on GF parts site, does not show a reference number for the screws, shot them an Email, to which they responded "are not included with "counterweight nylon's" But we have them. Can anyone tell me of an equivalent source? Also I have no manual for this bike, is there a link for crank width specs? I searched manuals and only came up with a very generic 03' "Owners manual" that had no relevant specs- Such as piston to cylinder clearance. Have .004"learance now with Wiseco piston which has 66.35 stamped on dome, Wossner piston site shows a "D" piston @ 66.43. Anyone have real world values on these? Also opinions on rod kits needed. My 05' 300 and my sons 02' 250 have Vesrah rod kits in them, does anyone prefer the Wossner rod? and if so why? Main bearing numbers? Can I get equivalents from bearing distributor? Gasket kits? Which brand fits good? Thanks!
TeamFlannelOutdoors-somewhere South of I80 05' Gas Gas 300 DE (Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC Moto Farm motor and suspension service 309 310 2540 leave a message www.halls-cycles.com Last edited by motorhead; 06-04-2016 at 11:01 PM. |
Crank bearings
1 x LHS CRANK BEARING SKF NJ206ECP - C3 62x30x16 1 x RHS CRANK BEARING SKF 63/28 - C3 28X68X18 1 x LHS CRANK SEAL KOK 20x35x6 - VITON 1 x RHS CRANK SEAL KOK 38x52x7 - VITON This information is stickied somewhat conspicuously in the Chassis & Body section. No other information for you, sorry. |
As far as gasket kits I like Athena. Good quality and customer service. I've had an issue and it was resolved quickly.
Matt 1999 GG EC 250 Six Days 1999 Cagiva Gran Canyon 2001 Aprilia Falco 2001 Triumph Speed Triple for my 20 year old 2000 GG XC250 for my 20 year old 2003 Honda Rancher 350 for the wife |
Thank you GGrider01 and hadfield4wd!
Once again anyone else chime in with crankshaft stuffer bolt info? Still cannot find a "service manual" online Looking for piston clearance crank width big end side clearance specifications
TeamFlannelOutdoors-somewhere South of I80 05' Gas Gas 300 DE (Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC Moto Farm motor and suspension service 309 310 2540 leave a message www.halls-cycles.com Last edited by motorhead; 06-04-2016 at 10:58 PM. |
Unfortunately I don't think you'll find a service manual for '02. I have one for '06 if you need. The only change is the crank bearing type and yours might be new enough to have the newer style bearings, I don't remember when they changed. All other specs remain the same. PM me with your email address if you want it. In a few hours I'll be off-line until Monday because of travel.
jeff '00 XC250 (mine) LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion. '04 EC250 (the kids) (he can do his own mods haha!) |
I used .002 clearance measured at the skirt (bottom) of the piston. I didn't have a bore gauge, so I measured bore below ports with piston installed normally, then turned piston upside down to measure clearance above the ports. This was on a '01 XC 200 with B piston/cyl.
There is a Gas Gas repair manual online. I found it when doing the top end on my bike. That's where I got the piston clearance specs from. I found a Athena top end gasket kit online. It was inexpensive, very complete and worked well for me. I used a Wossner piston kit, just because of their good reputation. Someone on this forum recommended Niks Industries online for Wossner kits. Lowest price I had seen and quick free shipping. It was a good tip, imo, so I'm passing it on. No info on the screws you need, sorry. RB |
ohlins rear shock rebuild info? | houndog | Enduro Suspension | 3 | 11-04-2014 05:09 AM |
2002 xc250 wp or marzocchi forks....which do i have? | 70455 | Enduro Suspension | 2 | 06-08-2012 05:58 PM |
need set-up info 2002 xc250 gas gas please | motorhead | General Discussions & Announcements | 4 | 11-11-2010 02:22 PM |
2002 XC250 for an old guy? | wpwarhawk | General Discussions & Announcements | 6 | 06-25-2008 04:36 AM |
