Old 12-03-2011, 09:40 PM
matt_tidball matt_tidball is offline
Default 2011 zokes finally fixed(for real this time)
I have been hesitant to post this, but I have ridden it for a month now at this setting and it is great everywhere now! I think the two main keys were tons of rebound shims and I dumped the stock valves and installed hi flow valves from Tecnik in australia. I also lowered the preload to 2mm. After 12 times in these forks they are BUTTER!!!!! No spike ever now. Thanks to my local tuner Randy for all your patience.
Old 12-05-2011, 02:59 PM
Synergy-Seals Synergy-Seals is offline
Sounds right. Too much rebound and low flow bv always cause issues.
On my 48mmday sacks I flipped one bv added a id spacer to take up the cbore gap and added a couple larger shims. The rebound flow ports on the bv are much larger...thus is why I flipped it.
the forks track much better and don't dart around. I will be performing the same on the other fork.
www.synergyseals.com
209-938-9726
Being BOLD is BOLD! However, being confident is certain!
Ride with confidence again!
Made in the USA
Old 12-05-2011, 08:12 PM
GMP's Avatar
GMP GMP is offline
You really think the base valves are a problem? I agree on the rebound and also run 1mm preload, but the base valves never gave me (or Les who valved them) any issues. I can slam rocks with no deflection, which would be a good indicator of inadequate flow. Could the newer Zokes have different pistons?
Old 12-06-2011, 02:28 PM
CACTUSREID CACTUSREID is offline
I just had a local tuner,Geoff at GP moto put the bigger port base valves in my 11 ec300 as well. it's cold here and i only have one initial ride (short easy one at that ) on these revalved forks. But my iniatial impressions were that all the good points of the fork were still there, and the sharp high speed jarring hits were non existant now. front wheel tracked very well and no deflection. i'll post more on this as i get some time on these forks, but that probably wont be until spring time.
Old 12-08-2011, 04:18 PM
BrentMartell BrentMartell is offline
I drilled mine and stacked the rebound like crazy and built a mid valve. Well the dealer helped with the mid valve. I have been into the forks a dozen times as well. Working good now and of course I am getting rid of the bike. Go figure.
2011 six days fork fixed (kinda) matt_tidball Enduro Suspension 54 08-16-2011 09:43 AM
Sachs vs Ohlins/Zokes in 2011? AZRickD Enduro Suspension 59 06-04-2011 12:08 AM
515 the REAL DEAL hasslbri Ride Reports 40 04-14-2008 01:03 AM
Firefox formatting issues fixed... webmaster General Discussions & Announcements 1 07-17-2006 08:11 AM
