Old 06-28-2013, 03:10 PM
Corey Corey is offline
Originally Posted by drehwurm View Post
BTW, are the guide pins for the floats just pressed in? The one-piece float of the Keihin PWK seemed to be a surprisingly good fit when I checked. Seems possible to make a conversion, but I'd need to remove the stock guide pins.
Michael
The guide pins are pressed in. The Keihin floats will fit, but the plastic webbing support hits the bottom of the carb body. We are designing a POM material one piece float and are working on tooling.
Old 06-28-2013, 03:48 PM
Diggs345's Avatar
Diggs345 Diggs345 is offline
Originally Posted by Corey View Post
You talking about the metering rod or the fuel inlet. Not custom MR just carefully measured.
Looking back through my mail you said the 3.5 needle and seat.
Old 06-28-2013, 07:00 PM
Thanks Corey! This conversation is really appreciated. Removing the smart carb is a bit of a chore, so if the new metering rod doesn't solve my issues I'll then move onto the floats again, although I checked and measured several times at initial install they could be playing up I guess. I'll have the shock removed for a revalve shortly so this will provide the opportunity to get to the carb. Two birds with one stone!
Old 06-29-2013, 01:09 AM
Rick's Avatar
Rick Rick is offline
It's the fuel
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 06-29-2013, 02:58 AM
Originally Posted by Rick View Post
It's the fuel
I wondered this myself. Every spec I have read for every brand of bike there appears to be notable differences in fuel requirements between the states and Aus/Europe. In saying that the Smart Carb should still be able to cover those variances with the same metering rod.
Old 06-29-2013, 04:24 PM
Originally Posted by Diggs345 View Post
Thats the way i check my float level , is that 20mm on the new float bowl corey ? , i cant get anywhere near that with the bike in the meat of the powerband without the bike sucking the cab dry .
A 3.5 needle seat is headed your way, sent a week or so ago and is a step larger than your current float inlet seat. I'm still inclined to think that there is something in your current arrangement that is not letting the float needle come all the way off the seat, even though it's stacking up to the correct fuel height. Meaning some float inlet needles and seats seal better than others and you may have yours adjusted so as to hold the proper height, and not flood, but there may not be enough total travel in the floats to open the valve all the way, which slows down the fill rate. Also we have seen more than our share of bikes and quads that don't have adequate venting at the tank that can also slows down the fill rate of the bowl. Your current needle and seat (3.0) should be adequate as we have the same in bikes up to 500cc and lightly modified. Big bore open desert racing I recommend the 3.5 needle seat though.
Old 06-30-2013, 10:53 AM
Diggs345's Avatar
Thanks Corey , look foreword to trying it out .
Old 07-11-2013, 04:53 PM
redrider's Avatar
redrider redrider is offline
Orded one today! 38mm cast.
Old 07-11-2013, 06:28 PM
New MR received. R080.
Will test it in days ahead.
Old 07-15-2013, 04:19 PM
forgiven forgiven is offline
Have we gotten any idea as to when our next milestone is?
APT SmartCarb siaknijustin Enduro Product Announcements 19 10-02-2012 08:12 AM
