Old 03-21-2009, 11:23 AM
nwcycle's Avatar
nwcycle nwcycle is offline
Default 2001 200 Timing Question
I Had remover stator searching for running problem, Could anyone out there help with the correct mark for timing, The bike was Dying out when it was warm, I have a coil tester and that was not it, also tried a different coil,
The bike will only run when cool, so just looking for any insight, also the stator area was dry, only looked like condensation.
Thanks All
Shutup and Ride !!!!!
Old 03-22-2009, 02:43 PM
darren's Avatar
darren darren is offline
When you say dying out do you mean intermittant misfire then dies or just dies with no warning??
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 03-23-2009, 10:18 PM
nwcycle's Avatar
it feels likes its running out of fuel, which its not, full tanks, starts and runs perfect when cold, Will run for approx 10 min, riding easy, when you ride race pace, 5 min tops and dies out. let sit 10 min. or so. will start and make it approx .5 miles and dies again
Not sure of the orig timing mark as it was set where you can see the bolt mark, not even close to the punch mark
Thanks
Timing a 450? iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-28-2010 10:17 AM
07 timing? wence Enduro Electrical & Wiring 15 10-28-2009 03:42 AM
2001 300 rear sprocket question forgiven Enduro Chassis & Body 1 04-27-2009 04:48 PM
Need HELP with timing gasser Enduro Engine - 2 stroke 2 03-23-2009 02:17 AM
450 Cam Timing question Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 4 04-09-2008 08:57 AM
