Old 02-19-2019, 05:12 AM
Wimpy525 Wimpy525 is offline
Originally Posted by fred99999au View Post
Hey Wimpy525 how did you go about removing the bevel gear and the shaft?
Was it just heat and BFI? (Brute Force and Ignorance)
I never did get it out, my dealer took another ignition cover and shaft off the shelf. Pretty sure he did this out of the kindness of his heart. But the bearing is the same as the water pump.
Old 02-19-2019, 07:24 AM
Wypipo Wypipo is offline
Originally Posted by Zman View Post
I did not mention a bearing.
Sorry I quoted the wrong post but I see wimpy has already answered it.
Old 02-19-2019, 07:27 AM
Originally Posted by farmerj View Post
It seems like the 220 CCA Shorai would be enough. One way to find out is to hook up to a bigger battery with known higher CCA just to find out if that works. For instance, I set a jet ski battery (360 CCA or so) on the subframe (since it wouldn't fit in the battery box) and attached the cables as a test. My bike started right up.
With a CCA that is too low, sometimes the engine will spin over just fine - it cranks nicely...and cranks, and cranks...without starting. I am with those who believe that there is a large amperage draw somewhere in the system (maybe the starter) which does not leave enough to create a strong spark.
Info. on an 240 CCA battery can be obtained from GG Tech Bulletin TB-GG-17-12 which I will send to you, thanks to Kiwigasgas (http://www.gasgasrider.org/forum/sho...t=23392&page=7).
Have your dealer contact GasGas USA per the bulletin. They recommend an Antigravity YTZ-8. My dealer only got $10 off of the list price; I had expected the discount to be higher. But there may have been some confusion in our communication with GG.
Don't stop trying things until you figure things out and get that starter fixed! It is possible, and you will be happy! It's a great bike
Jeff
The only other battery I have is my car battery. Could hooking up a battery this big possibly damage anything?
I hope I can get this figured out, the bike is awesome but I have a GP and harescramble series starting soon and all the races are deadstart which I?m worried about right now.
Old 02-19-2019, 10:01 AM
dzhitshard dzhitshard is offline
I would not hook a car battery up to jump or start your bike.
One of the biggest shadows you're going to be chasing is "CCA" ratings by powersport battery manufacturers. None of them actually use the "CCA" standard and have their own formulas for coming up with what ever numbers they print on their website and they often don't line up from one company to another. I look for what companies document for "burts" rating etc. Amperes over a 10 second crank etc. I also don't mess with batteries that don't have a built in battery management System/circuit "BMS" but that's a different subject.
Have you removed the starter mounting bracket and the ground points and made sure there is no powder coat or corrosion causing resistance? My cranking improved a lot when I pulled the starter mounting bracket and sanded off all the black powder coat and then the red powder coat on the frame lug under the coil.
What's the actual battery voltage measure before you crank? What about during and after?
Old 02-19-2019, 11:21 AM
Neil E. Neil E. is offline
As long as the polarity is connected correctly, a car battery can be used to jump start your bike. There is no problem. Just be careful with the connections. The car does not need to be running.
Old 02-19-2019, 03:19 PM
I did this one my bike as part of it's predelivery/pre ride setup. No other upgrades to cables, batteries, etc.
Old 02-20-2019, 10:53 AM
450exc115 450exc115 is offline
I do this for all electrical stuff that uses the frame as ground. Helps with everything from the coil to the E-start even the battery terminal to ground.
I raced a KTM 450XCF for several years, this motor had NO KICK starter and E-start only. The ground circuit was battery to subframe, subframe to main frame, frame to motor, motor to E start... All of them had coatings on them. I sanded all of those touch points added a slightly higher cranking amp battery and would pull holeshots on dead engine starts regularly.
I also make sure the ignition coil is sanded to the frame...Every little bit helps.
Old 02-20-2019, 05:36 PM
exactly. And on this bike my starter bracket was fully powder coated and providing a lot of resistance.
PS, for the OP.
It would really benefit you to take some posts cautiously regarding "I jumped my bike with my car and there's no problem with it" type posts.
Take it at face value and you may miss some pertinent information like was the bike battery a LiON type, if it was did it have any over/under voltage protection, how long was the connection made, how far out of balance was the amp capacity between the bike and car battery. Unless I stood a chance of dying in a Himalayan snow drift next to my dead bike there is no way I would connect a Shoria to a car battery in attempt to start it.
Old 02-21-2019, 12:54 AM
SS109 SS109 is offline
PS, for the OP.
Using a car battery is 100% safe to jump start a bike regardless of battery type or amperage rating. A battery is nothing more than a storage unit for an electrical charge. How it's stored or how much amperage is available makes no difference. The only time you would possibly have an issue is if jumping from a running car. In that situation the alternator from the car will actually be pushing current and could be too much for the electronics of the bike.
Old 02-21-2019, 09:06 AM
Which part are you guys saying to sand and make sure there is metal to metal? Is it part #19 ? That part feels like plastic to me?
Swopping 1997 Cylinder head with 2005 head EC250 Enduro Engine - 2 stroke 10 12-15-2015 10:13 AM
200 jug and head frankinberg "Wanted to Buy" & "Want To Trade" 0 11-08-2015 05:44 PM
Coolant leaking through cylinder head socket-head bolts. GGRider01 Enduro Engine - 2 stroke 5 10-17-2015 07:38 PM
How to tell if Head mod has already been done? 2004ec200 Enduro Engine - 2 stroke 4 09-08-2014 11:42 PM
S3 head bkwdc Enduro Engine - 2 stroke 6 01-17-2014 01:14 AM
