Old 09-27-2018, 12:54 AM
Checked the reeds lately?
Old 09-27-2018, 01:04 AM
icebergstu icebergstu is offline
Yep...immaculate
Sent from my SM-N950F using Tapatalk
Old 09-27-2018, 01:06 AM
I'm going to grab the mikuni I had on my WR300 and see if that will fit.
I jetted that once and it was perfect for 700hrs.
Stu
Old 09-27-2018, 02:30 AM
It'll let you know if the carb is at fault or something else at minimum.
Very strange that the idle screw has no effect. Has the tip been snapped off it or something similar?
Air screw can have little effect until you get everything else where it needs to be.
Old 09-27-2018, 07:43 AM
When setting up the carb off bike the idle screw is pushing the slide up no probs.
I'm starting to think air leak, electrical, timing, so many potential possibilities....
Old 09-27-2018, 10:50 AM
Zman's Avatar
Zman Zman is offline
I would double check the crank seals. Especially the one on the clutch side as it will consume trans oil and make jetting impossible.
Old 09-27-2018, 11:16 AM
Motorman_55792 Motorman_55792 is offline
Sounds like a worn carb. What would be a needle jet in a Mikuni and made of brass is not replaceable on a Keihin and aluminum. The needle will over time wear that hole larger and make for a rich low throttle mixture. I had to go to a larger (leaner) base diameter needle on my bike with similar issue. Same needle with an "E" first letter in stead of the earlier "C" first letter. Now I could turn the idle down and adjust the air screw with results. A new carb is the real solution, but mine is a RB modded carb and I like it again with this change.
Old 09-29-2018, 01:23 AM
So....swapped out the Airstriker for a Mikuni TMXX38 from a 2011 Husqvarna WR300...
Wow...now I know why everyone falls in love with these bikes!!! Brilliant!!
Smooth, powerful and Linear from the bottom all through the rev range!
Love it.
Thank you to everyone who has helped out, it's so hard to diagnose a worn carb but we got there in the end!!!
Stu
Has the porting changed between years? motopsycho87 Enduro Engine - 2 stroke 7 04-28-2018 05:46 PM
2015 EC300-E Changed-UP Born2Ride Pictures & Videos 0 11-07-2016 12:31 PM
2002 Gas Gas EC300 Jetting Issues Vergey Enduro Intake/Carburetion - 2 stroke 13 10-28-2014 04:31 AM
have radiator hose's changed ? motorhead Enduro Engine - 2 stroke 3 05-08-2011 12:00 PM
PWK replacement resolve idle, jetting issues? socalscott Enduro Engine - 2 stroke 2 01-04-2010 12:32 PM
