Old 12-03-2018, 03:00 PM
Trailrider Trailrider is offline
Default kickstarter crossover
YZ part # 5nx-15620-00
Old 12-04-2018, 01:15 PM
Undertow Undertow is offline
A quick recap on this.
Got the Woodruff key and new battery from importer.
Installed both.
The result is a bike that now starts very nicely with kickstarter and also runs totally differently than before. No kick back at start, no stalling, nice torque and no vibrations. Finally I have a bike that is living up with the reputation of a 300 2-stroke.
So all the problems of the bike were due to the rotation of the flywheel and too much advance in ignition.
The battery didn?t do any magic with the electric starter, still useless (does not turn the engine even one revolution). But anyway I can ride the bike🤟
P.s. There is a small return favour in the sticky maintenance manual thread...
Old 12-10-2018, 04:00 AM
I am glad you got it sorted. Being an old grandpa I still learn new things every day.
Concerning the starter, give it some time, use it only when the engine is fully warmed up. It sounds weird but it gets better after the first 30 to 40 hours. The cinstruction of the gears, especially those under the small cover is, lets say it friendly, not the best...
Old 12-20-2018, 03:57 PM
All is well that ends well.
Got a new starter from the importer and now the engine practically explodes running.
The old starter never started the bike like this, even when brand new. And after some hours of trying it just died.
So now I finally have the bike that I put the money on the table for.
Me so happy
Old 12-21-2018, 01:41 AM
Wuzofoz Wuzofoz is offline
Good to hear it?s all sorted now
Old 12-21-2018, 02:56 AM
Great to hear that!
Now have fun with it!
Merry Christmas!
Doc
Old 12-21-2018, 09:09 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Great news, I'm glad you stuck with it and you able to get it sorted out.
Have fun! Dave.
Old 02-14-2019, 03:34 PM
wpnsx wpnsx is offline
Hello All,
Thanks for all the very useful information sharing throughout this forum!
I have an 2018 300 GP just clocked over 18 hours, besides the E-start only working a handful of times when warm the bike handles amazing and makes awesome power. Now after doing the second oil change (to Motorex Gear oil 10-30 from Castrol Power 1 Racing 5-40), the bike is not idling as well as it used to and is giving the odd kick-back when kickstarting. After a rev of the engine as it returns to idle it sounds like it is "hunting" and the idle is not high enough to keep it running without revving it plus it does not rev as crisp of idle. 2 days before it was running perfectly.
It still seems to be running fine on the track wide open but you do notice the hunting on decel into corners.
Any ideas on what might be the cause here?
Air filter was on the dirtier side but no signs of anything making it through.
Any thoughts would be hugely appreciated.
Old 02-14-2019, 11:36 PM
Davehuge's Avatar
Changing the gearbox oil wouldn't cause the problems you've explained.
Try the simple solutions first, try a new spark plug.
Also could be caused by a small blockage in the carb, for example debris blocking the tiny orifice of the pilot jet.
However,
I'm wondering if your ignition timing has slipped, that could cause the issues you're having.
If you read back through this thread you'll see Undertow's ignition timing slipped because the woodruff key had sheared, the woodruff key locates the flywheel on the crankshaft and together with the position of the stator plate, sets the ignition timing.
His bike was also a 2018 model. If the nut securing the flywheel was not tightened/torqued correctly it could allow the flywheel to rotate on the crank and shear the key.
Shouldn't jump to conclusions but there's a possibility there's a batch of bikes with this issue caused by a problem on the assembly line, for example if an assembly worker's torque wrench was faulty, not set correctly or he picked up the wrong torque wrench.
Let us know how you get on.
All the best, Dave.
Old 02-25-2019, 03:02 PM
Hi Dave,
Thanks for your thoughts here. Yeh I was trying to imagine any possible way oil could effect this but also didn?t think it was possible.
Today I took the carby off, bowl off and cleaned it. There were no deposits that I could see anywhere but I did not have a the perfect sized flathead screwdriver to take the pilot jet out so just sprayed carby in there.
I went and tested the bike this afternoon and the issue remains. Didn?t seem to be kicking back at all but it was still hunting on decel.
One thing I did notice was the engine side boot hose clamp doesn?t seem to do up particularly tight. Could be an air leak. Next thing I will try is the air screw, and spraying some brake cleaner around that boot. Then I?ll have to get back in and get the pesky pilot jet to make sure it is not blocked.
2018 gp300 Colt New Bikes 1 02-10-2019 04:55 PM
First Ride 2018 GP300 Wimpy525 Ride Reports 7 09-24-2018 10:29 PM
2018 Gasser GP300 Colt GasGas Member Polls 27 07-12-2018 08:10 PM
2018 gp300 Colt Used Bikes 2 06-22-2018 08:14 PM
2018 GP300 instruments fred99999au Enduro Electrical & Wiring 6 05-08-2018 07:27 AM
