Old 02-04-2019, 06:16 PM
(F5)'s Avatar
(F5) (F5) is offline
So. . . Have you tried a needle from your other bike? My PWK35s I bought for my RZ had like a DEK (also gold but had writing so its strange yours dont) in them but just maybe it is restricted flow at open throttle.
Just to clarify does the power plateau or does it break up? And is that revs related or only throttle position as you imply?
Again while you have swappable parts do the cdi, coil, plug and if you get desperate the stator but will need loom swap or to add connectors (I just recrimped mine back together when changing my stator). Check the Earth connection is clean and not hanging on by a few threads.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 02-04-2019, 06:59 PM
Zman's Avatar
Zman Zman is offline
Originally Posted by (F5) View Post
So. . . Have you tried a needle from your other bike? ?.. Again while you have swappable parts do the cdi, coil, plug and if you get desperate the stator but will need loom swap or to add connectors (I just recrimped mine back together when changing my stator). Check the Earth connection is clean and not hanging on by a few threads.
Also double check your spark plug gap. Too large of a gap can be a problem at higher rpms.
Bike bogging at wide open throttle Mostin3 Enduro Intake/Carburetion - 2 stroke 9 11-04-2017 03:09 PM
open end aluminum throttle tube? 95jersey Enduro Chassis & Body 2 01-11-2017 12:34 PM
2012 EC 300 clutch problem, and low spd. throttle jerk.... mp5 Enduro Engine - 2 stroke 12 06-30-2013 10:01 AM
Fuel range problem!!!Ec250 2011 thomas.gr Enduro Engine - 2 stroke 4 03-03-2012 03:06 PM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
