#11
On my 07 GasGas it had one of those instead of a thermostat (#16). On my 2012 the thermostat deformed and I could not clamp a hose to it so I replaced it with one of those.
#12
Please don't mistake me for any kind of expert but I'm surprised that something like this would make much difference. The added surface area seems to be fairly small as a percentage of the radiator surface.
If cooling is an issue, would an uprated water pump not be a better option to shift the coolant faster round the radiators? Or a radiator fan to improve cooling airflow rates in slow riding? Probably would ditch the thermostat as it must restrict water flow even when fully open. |
#13
With regards to replacing the thermostat with one of these I have always worried that you have a hard edgy metal piece right next to your radiators, the chance of it rubbing a hole in the rad must be quite high and definitly outweighs any heat transfer benefits. with regards to heat transfer you will be better off fitting a fan kit from the GG trials bikes and a manual switch to turn it on and off as you want
#14
I have made a mod to pipe 16 and I was concerned about radiator damage but with some care it is non issue.
I've cable tied a small bicycle pump mount and velcro'd the pump on. All things considered it's far more likely to be useful.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
450 Oil cooler? | Dave99 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 09-16-2017 07:45 PM |
In line cooler. | Leo | Enduro Chassis & Body | 3 | 08-29-2012 09:26 AM |
inline water cooler? | nato | Enduro Engine - 2 stroke | 14 | 05-15-2012 06:23 PM |
