2018 Head o ring gaskets
Can someone confirm the head O rings are indeed parts 7/8 on the parts fiche?
I ordered an aftermarket head and I normally would like to install it with new o rings. I went to order one and the parts fiche shows one O ring as what appears to be #8 but lists it as crank case reed gasket. The part number is no where close to #7 which is labeled as cylinder head O ring. I want to make sure I don't order the wrong thing and have to wait and extra week. Thanks |
7 and 8 are described correctly in the MY 2019 parts list, if that helps.
I'm not seeing a 19 model year drop down option on the 2 sources I know of for the parts fiche. If it's not too much trouble can you give me the part numbers your 2019 fiche shows?
ME25916060 for the outer.
ME30916065 for the inner. Assuming this is for a 300. The 200 and 250 inner is part ME25916065. Don't quote me on this but I believe that the equivalent KTM parts fit if that is an easier option for you. I may be wrong. |
yes the KTM part would be easier for me if I knew that they worked. I have a couple sets of those in the parts box. I just can't risk cracking it open and them not working this weekend. It looks to be a near perfect, snowless frozen ground course and I'd be really depressed if I missed it. |
2018 ec250 piston and gaskets | Wuzofoz | Enduro Engine - 2 stroke | 4 | 10-29-2018 05:45 AM |
Re-use head gaskets/o-rings? | Terrence R | Enduro Engine - 2 stroke | 6 | 04-01-2016 06:15 PM |
Head gaskets, what's the trick? | GGRider01 | Enduro Engine - 2 stroke | 9 | 10-11-2015 12:19 AM |
Head o ring | Dude | Enduro Engine - 2 stroke | 0 | 05-21-2011 09:28 AM |
Head-gasket O-Ring question | FFRDave | Enduro Engine - 2 stroke | 5 | 01-12-2008 09:56 AM |
