Seized front axle
I tied to remove my front wheel today to just do some general maintenance. Front wheel bearings.
Tyre change Fork seals Well anyway when I went to remove the front axle it seems like the center bush has seized on to the axle I?ve tried knocking it out with a socket while pulling on the other side but no luck just spreading the forks apart I tried adding a little heat but still no luck I don?t want to damage the forks by spreading them to much or anything. Has anyone made a puller with some tube and threaded bar so you could pull out the axle without spreading the forks? Also anyone know the numbers off the bearings so I can order them ready for when it finally comes apart ? |
Does anyone have the measurements for the axle OD of the smaller part where the end cap screws in and the OD where the axle puller is located cheers it?s a 2012 model as well cheers
Take off the complete front end of the bike.
Slide the forks off the axle. Tap the axle out. The bearings will come out of the wheel on one side, along with the center spacer. You can then apply heat to the spacer. There's no snap rings on the front wheel. |
The quick action of an air hammer might help you out too. Make sure to use the blunt end attachment for removal.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
I fully agree!
Got it out. So simple why didn?t I think of it
Just remove front forks slide of the axle and knock the shaft out the right hand side. Heated up the aluminium center bush and that just slid off. The bearing proved a bit more of a challenge tried to hit it off with a hammer no luck so had to use the hydraulic press at work. Damaged the threads a little but just cleaned it up in the lathe and happy days just waiting for new bearings then back together with plenty of grease... now on to the fork seals😳 fun times. Hopefully be ready for the hare and hound Sunday |
That's why these forums are the "authority" on helping fellow GasGas riders.
Need Front Axle & Axle Nut | estwudsracer | Enduro Chassis & Body | 1 | 09-11-2013 12:23 PM |
Front Axle | noobi | Enduro Chassis & Body | 10 | 09-21-2009 09:51 PM |
