Old 05-28-2007, 08:17 AM
gevandam gevandam is offline
Unhappy Efi/ignition
Have a 2005 FSE450, Was running fine and lost power, could not restart, no spark. Battery was charged and still not starting, any Ideas?
Old 05-28-2007, 06:25 PM
fury1's Avatar
fury1 fury1 is offline
is there a fuse panel? may have a blown fuse?
Old 05-29-2007, 01:07 AM
bergerhag's Avatar
Does the fuel pump run for a short burst when turing on ignition? (does the headlight come on?) If not, there may be a solenoid problem. The same solenoid feed the ignition coil and the fuel pump. Solenoids are located behind the right side panel. I think the fuses are there too.
1. check fuses
2. If/when fuses are ok and pump still not running, switch the two solenoids.
if fuel pump is running and still no spark, disconnect the ignition coil connector and use a voltage meter and check that 12V is present at connector pin 1.
Get a replacement coil(kinda expensive, tho).
Check all connectors for bad connections, oxidation.
Use the electric schematic from the manual as an aid in troubleshooting. Be patient and thorough.
Keep us posted on progress.
Old 05-29-2007, 04:21 PM
Nick's Avatar
Nick Nick is offline
Possibly the relay. Take off the right side cover and switch places of the 2 there.
Old 05-29-2007, 05:31 PM
Tom Zelko Tom Zelko is offline
I have had the same problem.1) the relays in the airbox 2) fuses in air box area and the headlight area. 3) the on off key, the wire breaks under the silicon, I use a togle switch now. 4) the fuel injector. Try this order also check for any broken wires behind the light. All the info before this looks good. Good luck. Tom
FAQ : Which ignition do I have? jeffd Enduro Electrical & Wiring 24 07-06-2009 12:47 PM
04 300EC Ignition changed to DE Ignition Trail Blazer Enduro Engine - 2 stroke 0 01-08-2007 01:48 AM
